  • Guests: 26
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Heatsinks and electrical insulation.
Ken M.
Sat Sept 15 2007, 12:03AM Print
I know alot of you guys place 2 or more fets or heatsink mountable semiconductors to the same heatsink. What I'd like to know is, what and where do you guys get the insulators for these parts? I'd like to know since I'm starting work on Skoris SSTC and was going to use an old P2 heatsink to mount the power fets and transistors, whoever looking over the datasheets and the schematic, it would be shorting out alot of spots.
Carbon_Rod
Sat Sept 15 2007, 01:45AM
Mica washers + nylon collars
Newark or Digi-Key
Sat Sept 15 2007, 05:08AM
Personally I like to NOT use insulators if possible,
I prefer to have heatsinks directly connected to the drain of mosfets or collector of bjts,
of course this means using multiple heatsinks,
but the benefit is MUCH better heat transfer from transistor to heatsink.
Heatsink compound helps even further with heat transfer.
e.g. for a TO220 transistor the thermal resistance from junction to heatsink is about 1 celcius per watt
a typical insulator will double this figure, which means half the power can be dissipated.
(or the device temperature rise will be double)
If you use mica then also use 'heatsink compound' (typically tin-oxide in silicon grease)
don't bother with expensive heatsink compounds if you use an insulating pad. (silver-loaded etc.)
Most commercial products now use 'sil-pads'
which have a higher thermal resistance but don't require heatsink compound.
These grey looking sheets can be recycled from many consumer devices.
Two small heatsinks without insulators works MUCH better than one double-size heatsink with insulators.
If you do use separate heatsinks without insulation consider the voltages on the heatsinks regarding safety.
Experimentonomen
Sat Sept 15 2007, 09:49AM
Silpads are teh best, no sticky white stuff and better thermal conductivity than mica washers.
Sat Sept 15 2007, 10:20AM
Yes, Sil-Pads are pretty good, and most good electronics distributors sell them. They are also known as heatsink pads or greaseless insulators, I think, but a quick look in the Mouser or Digikey catalogue should turn some up.
Marko
Sat Sept 15 2007, 11:16AM
Hm, and I used grease with sil-pads too.
Experimentonomen
Sat Sept 15 2007, 12:27PM
No need to do that, Marko.
Marko
Thu Sept 20 2007, 10:49PM
Is there any wrong about using grease with sil-pads? I thought that if there are still some gaps in there, it's better that they are filled with grease than with air.
Zum Beispiel
Fri Sept 21 2007, 07:33AM
Lots of eletronic junk I've taken apart use grease between the sil-pads and heatsinks.
If the heatsinks surface is smooth enough adding grease between the pad and the heatsink won't make a difference. I still like to use it tough. I like to think it helps to fill any small "gaps" between the pad and sink. Makes replacing dead parts a lot messier, tough.
So, using grease with sil-pads shouldn't be a problem, and might even help a little (as long as you don't go overboard and use like 10g of grease mistrust)
