  • Guests: 35
WarrenR (64)
currentkills91 (32)
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
I need 50 pre-made driver devices
highpockets
Fri Sept 14 2007, 07:02PM Print
highpockets Registered Member #1002 Joined: Fri Sept 14 2007, 06:28PM
I need a 12 volt input device that when connected to a grounded spark plug will arc the gap with a continuous spark. Preferably already made, but if I have to build it that is ok. I need to produce about 50 a month. I hope it is not against forum rules to make this request for help. Can anyone point me in the right direction.
Thanks
EEYORE
Fri Sept 14 2007, 11:55PM
You need an ignition?I would guess, iginition coil and one of the many drivers for it. Google ignition coil driver and youll have what your looking for.
Matt
ragnar
Sat Sept 15 2007, 12:48AM
50 a month? What are you building? Who are you selling to?
Please be more specific.
Electroholic
Sat Sept 15 2007, 12:59AM
ccfl drivers?
Carbon_Rod
Sat Sept 15 2007, 01:42AM
Cattle prod from farm supply -- as many as you want and cheap....
Sat Sept 15 2007, 05:17AM
I doubt that you can maintain a continuous spark using battery power
I assume that you mean many sparks per second.
If you are going into volume production you need to be a little more specific.
e.g.
- Minimum number of sparks per second
- Minimum acceptable spark gap distance
- Pressure of spark gap gas
- Ideally minimum spark energy acceptable
- Duty of device e.g. 10 sec/min, continuous for 5min. etc.
This will allow for a reliable and economical design.
Marko
Sat Sept 15 2007, 09:30AM
Why not? You can mantain any kind of spark you want with enough power ;)
ragnar
Sat Sept 15 2007, 09:50AM
I still don't understand why we're doing your procurement and design for you -- is this so you can capitalize by reselling them? Nothing wrong with that -- but what're they for? Can you fill in some of Sulaiman's specifications?
Sat Sept 15 2007, 10:09AM
Yes, this site is intended as a resource for hobbyists, and people with commercial design questions should remember that everything published here goes under the Creative Commons license.
Some of the people here are experienced EEs and will let you hire them as consultants outwith 4hv, but it will cost you suprised
If I was in a hurry to make such a device, I'd go to my local McGuyver supplies store and buy a small neon sign transformer and a small power inverter of the kind used for running 120V devices in your car. A far more elegant, cheaper, and compact design could probably be made with a flyback transformer, or a modified electronic NST.
Marko
Sat Sept 15 2007, 01:45PM
For a spark plug, I don't believe he needs anything bigger than a CCFL or laser printer/copier HV supplies. Making the transformer is biggest problem, although for mass production somebody can do it for you.
