  • Guests: 30
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
wireless power
Guyfrom7up
Tue Sept 11 2007, 01:48AM Print
Guyfrom7up Registered Member #817 Joined: Mon Jun 04 2007, 01:33AM
What's I'm looking to do is to build my own air coil transformer. The plan is to have a big coil of wire (help me with the gauge and the length/number of turns) connected directly to an AC socket (can I do that, don't want to blow a fuse). Then have another, much smaller coil that will be 30gauge, convert the AC input to DC via the bridge recitifier, charging up a small, 10v, 2200 mF capacitor, which goes through a resistor lighting an LED. So whenever the reciefing end goes near the coil it'll light up. I just need help on the coil part (mostly on the AC end.
teslaguy
Tue Sept 11 2007, 02:48AM
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
look here: Link2 here: Link2
the first link is the one that didnt work but has a more complex circuit, the second link did work but you will need to design your own oscillator. Its not the same thing but its the same principal, good luck.
Tue Sept 11 2007, 08:48AM
Also look here Link2 and here Link2 and here Link2
Everyone seems to be using some sort of high frequency oscillator. 60Hz probably doesn't do anything except burn your transmitting coil up.
Avi
Tue Sept 11 2007, 01:19PM
yes, low frequency will not work for an air cored transformer. You will need something like 20khz to 100khz and it works fine with just 12v you will probably have at least 100v output if you use mains voltage (at the above frequencys) which is too high, you only wanted 10V output.
Guyfrom7up
Wed Sept 12 2007, 02:34AM
thanks guys, I might not use ac mains because I don't want to blow a fuse or electricute myslef, but if I were to it would be a step down AC coil, so it would be around 10v.
CT2
Wed Sept 12 2007, 04:09PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
You could try using the royer oscillator running off a little 12V step down transformer (even a little wall wart), instead of a flyback you would just use an air cored coil wound on a mouse pad like in the link.
Marko
Wed Sept 12 2007, 08:34PM
Hi Brian
You definitely need to be aware of what are you doing before plugging things into mains.
Regarding 50Hz, it doesn't need to necessarily be 'doing anything but burning your coil up'.
Your best try would be to get an induction cooker coil and powering it from low voltage transformer. If you are lucky you might be able to light a led from few centimeters of distance, with proper receiving coil. I think some people even levitated pieces of aluminium using those.
Surely don't expect anything spectacular from that, and don't bother to wind your own coil - it's too much work.
Going into high frequencies surely makes things a lot easier.
