  • Guests: 50
WarrenR (64)
currentkills91 (32)
09/14 Proud Mary (62)
09/14 omegalabs (39)
09/14 Plasma Lover (32)
Ultrasonic "fog" makers like in humidifiers
MikeT1982
Fri Sept 07 2007, 09:51PM Print
MikeT1982 Registered Member #621 Joined: Sun Apr 01 2007, 12:37AM
I've been wondering about this, I put my finger into a humidifier right above the metal disc that looks to me like a transducer of some sort, like a piezoelectric disc inside a siren, and my finger felt like it was heating up from the inside out! It actually hurt so I pulled it out fast LOL!
How do these things work, do they heat the water or just agitate it, and what frequency do you think it is? It was more like a hiss. Are the dangerous?
Mike
Electroholic
Fri Sept 07 2007, 10:42PM
its just an ultrasonic transducer. it breaks up water by introducing cavitation.
Shaun
Sat Sept 08 2007, 04:48AM
I had a weird lamp with one of those in it, plus LEDs. I put my hand in the water above the agitator and though i was getting shocked. I think its just a piezo disc in a water proof enclosure, probably anyone here could build one.
It was cool putting a couple drops of red food coloring in the water; see if you can guess what that does... wink
Bjørn
Sat Sept 08 2007, 06:01AM
The frequency is in the MHz range. The elements break easily because of the large forces, so if you touch it with something else than water it might get damaged quickly. The lifetime is short even when run in water, after about a year the amplitude should be significantly reduced unless it is running far below the rated current. The drive voltage is often 100V+ so take care when playing around with the driver.
I have heard about people getting something that looks a bit like burns that were quite painful so it is probably not a good idea to keep the fingers very close to the element.
Marko
Sat Sept 08 2007, 03:13PM
Hey, I'm curious about these things.. I never found any real good information about them.
From examination It appeared that there is a small, thin piezo speaker like those from toys and singing postcards driven by a little electronic circuit hidden in a box below.
Are you sure about that? The entire thing just appeared cheap for a circuit that would continuously pump 10's of W at that frequency.
Bjørn
Sat Sept 08 2007, 03:37PM
Yes, I am sure. I have seen frequencies between 1 and 3 Mhz, specific for the particular element used. With a resonant element and a prayer the driver probably can be quite simple.
CT2
Sat Sept 08 2007, 05:28PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
I have one of those in my basement right now that I have been playing with (I'll get pics after work tonight). I wouldn't put your finger in... it hurts quiet a bit. You can even melt plastic with the stream of water that rises off of the element.
Marko
Sat Sept 08 2007, 06:07PM
What size are the piezos used in those?
Andrew L.
Sat Sept 08 2007, 08:17PM
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
I have one of these in my room and it has a piezo with a 15mm diameter.
teslaguy
Sat Sept 08 2007, 10:56PM
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
water will disassociate best at 2.48mhz
