  • Guests: 35
WarrenR (64)
currentkills91 (32)
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Electrically spitting a candle flame
Ian Tresman
Thu Sept 06 2007, 05:21PM Print
Ian Tresman Registered Member #983 Joined: Thu Sept 06 2007, 02:37PM
Some time ago on the old forum, I enquired about splitting a candle flame with an electric field. Some more information may help solving this... and details on how to turn a flame into a speaker:
23o. Deflection of ions. The flame of a Bunsen burner which is fed with KNO3 solution by a wick, is placed between the plates of a large capacitor which is connected to the Wimshurst Electrostatic Generator. With the generator running it will be found that the flame splits into two halves, the positive ions being attracted to the negative plates and vice versa.
23p. Ionic speaker. Into the flame of a butane torch are placed two fine tungsten wires attached to the secondary of the transformer which steps the output of the audio amplifier up to approximately 1,000 volts. Ions are produced in the flame from a saturated KNO3 solution fed into its place from a wick. When music or any other audio input is played through the amplifier a distorted version of the input is heard from the flame. This is due to the motion of the ions in the electric field between the wires. If a photo cell is set up close to the flame, and the output amplified, it will be found that the light from the flame is also modulated. The quality of the sound may be improved by using a high voltage (500-1000v) DC supply to bias the flame.
See also: Electrostatic Deflection of Candle Flames (which includes some pictures)
Spedy
Sun Sept 09 2007, 04:48PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
You could do this with a normal candle, and a Negative HV DC supply. The positive ions in the flame are attracted to the needle on the output, and the other half of the flame is effected by the "electric wind" produced by corona on the needle.
So one half is "sucked" to the output needle, and the other half is blown away.
