  • Guests: 45
WarrenR (64)
currentkills91 (32)
09/14 Proud Mary (62)
09/14 omegalabs (39)
09/14 Plasma Lover (32)
mini (soon portable) ETG !!!
Lomy
Tue Sept 04 2007, 04:10PM Print
Lomy Registered Member #789 Joined: Sun May 20 2007, 09:32AM
heyho,
here's a little project i build today :))) . A mini mini mini ETG working with ~80j :) its triggered with a mini hf-ignition. ( like a teslacoil with just 10 sec. turns, which ionize the air , bla bla bla ... hope u know wot i mean :)(same as in a wig welding set )).
OK now time4pictures ;
and a little vid shooting with cotton wool :) :
teslaguy
Tue Sept 04 2007, 04:16PM
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
I googled for etgs and i found nothing...Is it a coil gun or what? Can you post a circuit diagram and better explain its purpose please?
Lomy
Tue Sept 04 2007, 04:41PM
a etg is an electic thermo gun, which use the mechanical energy of an elko to creat a little explosion and accelerate a projectile like a real gun : )
Lomy
Thu Sept 06 2007, 08:25PM
here a new vid shooting with it ;)
its in case, portable, 5 sec charging time, 118j and strong enough to shot through paper ;)
Lomy
Thu Feb 05 2009, 10:49PM
i finally finished the electrothermal gun =) after .. ahm over 1 year xD
total stored energy is 200j
the power level is really high, higher then any coilgun i build with the same energy input. i can shot throuh 2 thick tins and can make 1cm deep holes into houswalls (stone)
here some pictures of the plasma flame coming out of the barrel:
(the thing looking like a coil is pulstransformer for the trigger system)
and finally a demonstration vid:
Ultra7
Thu Feb 05 2009, 11:36PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Totally cool!
I want to make one now.
I like the sound of it too.
teslacoolguy
Fri Feb 06 2009, 04:17AM
Wow that's cool. Wouldn't mind building one myself smile
rp181
Fri Feb 06 2009, 04:18AM
what are you using as a fuel?
Lomy
Fri Feb 06 2009, 09:42AM
i use nothing as fuel, its a pur plasma etg. the caps are discharged by a little lightning.
here is a little schematic, which show you the funktion :
rp181
Sat Feb 07 2009, 01:00AM
You mean a triggered spark gap? Or are you vaporizing some sort of metal?
