  • Guests: 39
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
strange mot
Kristian
Sat Sept 01 2007, 02:40PM Print
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
I found this mot yesterday and I was wondering if anyone has ever see anything like this? It kind of looks like a flyback. I'm not very electronically inclined, so I'm having a little trouble figuring whats going on here. I see the transformer, capacitors and diodes, but beyond that I'm lost. Any info on this thing would be appreciated.
Dago
Sat Sept 01 2007, 02:56PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
That is a solid-state microwave oven powersupply where the "MOT" is a ferrite cored transformer which is being driven with high-frequency AC with the driver electronics.
sparky
Sat Sept 01 2007, 05:22PM
Ahh, nice find! Basically you have your power supply for a big solid state Tesla Coil already prebuilt for you. Find another and you could run a dual solid state circuit into a voltage doubler.... who knows right? Endless possibilties!
Kristian
Sun Sept 02 2007, 08:06PM
I don't know that much about solid state coils yet, or solid state anything for that matter. I'll hold on to it until I can identify the components and understand how it works.
I have tore apart 40 or 50 microwaves and have never seen one of these before, I don't know if I'll ever just happen to find another. Who knows though, I might get lucky.
Marko
Sun Sept 02 2007, 08:22PM
Most of new light ovens have these. As is, it's hard to use for a TC supply, it outputs only 4kV and is without filtering (100Hz buzz.)
Somebody clever enough could although hack it with a multiplier (which is easy with high frequency) and a filter cap on low voltage side, and power a TC. I haven't seen anyone doing that although.
Sun Sept 02 2007, 08:43PM
Marko wrote ...
As you can see from the circuit board there's already a multiplier/doubler of some sort.
I'm wondering, could you draw an arc off of one of these without blowing it up?
Marko
Sun Sept 02 2007, 09:09PM
Yup, but only 4kV for a magnetron. It simply imitates an iron mot with level shifter, and to power a TC it would need to be further doubled, and then used with resonant charging.
Coronafix
Mon Sept 03 2007, 01:15AM
I saw that Sam Barros uses one on his rail gun.
sparky
Mon Sept 03 2007, 06:28AM
PS: Don't let size fool you! These solid state MOTs are equally as deadly as a large iron core MOT.
Wolfram
Mon Sept 03 2007, 08:36AM
It is possible to draw arcs with them, but mine went into protection and had to be restarted when the arc went out.
