  • Guests: 34
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
multi-stage portable coilgun
JoeDarkon
Fri Aug 31 2007, 01:44AM Print
JoeDarkon Registered Member #485 Joined: Sun Jul 09 2006, 01:14AM
I am looking in to making a portable multi-stage coilgun and was wondering if I could get a decent amount of power from using 3-5 stages with 400V 330uf caps or should I get caps with larger capacity's? I want to make it hand held so I want to have smaller caps but I dont know if those caps will be too small.
Bjørn
Fri Aug 31 2007, 02:14AM
Just to get an idea, grab 3% efficiency out of thin air and calculate how much energy you will get into the projectile and use it to calculate the speed of your projectile.
If you are far off you need better capacitors and/or optimal design.
JoeDarkon
Fri Aug 31 2007, 02:24AM
I dont know how to do that for a multistage coilgun
Bjørn
Fri Aug 31 2007, 02:51AM
Just sum the energy of all capacitors you plan to use. You are not after a correct result but after an approximation that will give you a clue about how to adjust your design.
If you have 5 stages with one 400V 330uF capacitor each you have about 130 Joules of energy, that is about 4 Joules into the projectile if your design is pretty good.
