  • Guests: 38
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Vacuum Tube Flyback Driver
Matthew T.
Tue Aug 28 2007, 09:15PM Print
Matthew T. Registered Member #513 Joined: Sat Feb 10 2007, 07:30PM
Recently I got a hold of a few old valves (given to me by a friend). I know very little about them (valves that is) having only ever used silicon diodes and transistors and am looking at the possibility of building a simple project with the valves I have. I saw Steve Conner's valve flyback driver and was very interested.
Before I start looking through an old radio books to find out if the valves I have would be suitable for a very low power flyback driver (which may prove to be rather difficult considering that I know very little about valves), I was wondering if anyone experienced could tell me the answer upfront. And if that answer is no, does anyone have a suggestion of a project for which my valves would be appropriate?
Here is a list of the valves I have :
-50C5 (1)
-12AT6 (1)
-12BA6 (3)
-35W4 (2)
-12BE6 (2)
-12AV6 (1)
-35C5 (1)
Thank you,
Matthew
Myke
Wed Aug 29 2007, 12:32AM
-50C5 Pentode
Vh 50V
Ih .15A
Va max 150V
Vg2 max 130V
Pa 7W
Pg2 1.4W
-12AT6 Double diode / Triode
Vh 12.6V
Ih .15A
Va max 250V
Ia 1A
-12BA6 Pentode
Vh 12.6V
Ih .15A
Va max 330V
Vg2 max 330V
Pa 3.4W
Pg2 .7W
-35W4 Diode
Vh 35V
Ih .15A
Va max 330V
-12BE6 Heptode
Vh 12.6V
Ih .15A
Va max 330V
Vg2 max 110V
Pa 1.1W
Pg2 1.1W
-12AV6 Double diode / Triode
Vh 12.6V
Ih .15A
Va 250V
Pa max 1W
-35C5 Pentode
Vh 35V
Ih .15A
Va max 150V
Vg2 max 130V
Pa max 5.2W
Pg2 max 1.1W
This would be a very low power flybacks driver because you could get about 1W out with these tubes.
Vh: heater voltage
Ih: heater current
Va: anode voltage
Vg2: screen grid voltage
Pa: anode power
Pg2: screen grid power
Coronafix
Wed Aug 29 2007, 01:25AM
Here is a handy web site I use frequently.
Wed Aug 29 2007, 09:44AM
The 35C5 and 50C5 might be worth a try, but they are pretty low powered. You may get a few tiny sparks out of a TV flyback with them.
The first tube project I ever tried was a distortion circuit for my guitar, made with tubes from an old record player.
Avenger
Wed Jan 30 2008, 10:22AM
Avenger Registered Member #1275 Joined: Wed Jan 30 2008, 09:33AM
My vacuum tube flyback driver. It uses a 6P45S tube. With the voltage doubler it makes 3-4" arcs. Anode voltage 400V.
1201688521 1275 FT30560 1
1201688521 1275 FT30560 2
1201688521 1275 FT30560 3
Wed Jan 30 2008, 01:31PM
That's amazing Avenger, where did you find that beauty monster flyback? I want one too tongue
Avenger
Wed Jan 30 2008, 02:18PM
It is the flyback transformer from the Soviet color tube TVs. wink
