  • Guests: 25
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
Michael W. (36)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
IGBT flyback driver
Mon Aug 27 2007, 05:03PM Print
Hi all,
after some problems I finally got my IGBT flyback driver working reliably. The gate driver is built around the IR2153 half bridge driver ic and its outputs are boosted by TC4452's. The halfbridge is made of IRG4PC40W Warp speed IGBTs and MUR1560 ultrafast clamp diodes (2 in parallel per igbt). Resistive inrush current limiting, shorted by a turn-on delay relay.
The bridge drives 2 ac flybacks with 13 turn primary each, connected in series. Secondaries also in series (with "midpoint" grounded). No airgap.
Total arclength up to 20cm (8"), ca. 1kVA input max.
Pics
Gate driver
1188233595 152 FT0 Pict0165n
Flybacks1188233686 152 FT0 Pict0166n
I only tested it on a Jacob's ladder, since I feel a bit unsafe by drawing an arc with a hot electrode with 15kV on it...
Link to youtube video
Some captures from the video
1188233828 152 FT0 Capture8
1188233828 152 FT0 Capture10
1188233828 152 FT0 Capture12
1188233828 152 FT0 Capture13
Have a nice day wink
J.M.
Marko
Mon Aug 27 2007, 05:30PM
I fell sorry for those flybacks.. how much more can they take?
For those small IGBT's I don't se what's wrong with drive as simple as single SG3525 and GDT, actually I've driven larger gates that way without problems.
Again you may use bigger IGBT's with it if you come into need..
Have you considered building your own transformer for that circuit? wink
Mon Aug 27 2007, 05:38PM
Marko wrote ...
Hi firkragg, I simply don't like GDT's. I think my driver outputs almost perfect gate drive signal free of ringing and is virtually indestructible...
I've often thought about making my own high voltage transformer, but a large ferrite core seems quite impossible to get here.
Mon Aug 27 2007, 09:13PM
Madness! amazed Guess what I'm doing once my bench supply is done. Is the awesome arc in your avatar also from this driver? Just out of curiosity, how does the performance differ from a mosfet half-bridge?
I had planned on putting 4 monitor flybacks in series under oil, but I don't know if they will beat this.
sparky
Mon Aug 27 2007, 09:26PM
Impressive - gotta build me one of those :) Looks dangerous.... and I like that!
Tue Aug 28 2007, 07:21AM
Uzzors wrote ...
No the arc in my avatar is from some pole transformer captured from youtube video tongue
The performace really depends on how powerful devices you get- I think IGBTs are more suited for higher powers than FETs.
I have some problems with the arc starting, sometimes when it starts on the bottom of the ladder it sputters and bounces around like mad like if you were blowing at it from all sides, and it stays at the bottom. Restarting the driver (only the power part- gate driver is connected all the time) sometimes helps the arc to start again normally. This is really strange and I'm not sure whats causing it...
Edit- hmm strange, I rewired the flybacks with primaries in parallel and the sputtering seems to stop
sparky wrote ...
thanks, I think it outputs enough current to kill you wink ,it certainly is dangerous but nothing is dangerous when you know how to work with it smile
I've made a new video with a bigger Jacob's ladder here
Marko
Tue Aug 28 2007, 11:30AM
The performance really depends on how powerful devices you get- I think IGBTs are more suited for higher powers than FETs.
For low powers like two flybacks mosfets probably still win over IGBT's in price.
Those are quite large IGBT's from other side.
If you ever get larger cores you could use SLR and push like several kW of power with them.
Sun Sept 23 2007, 03:07PM
:-( Today my driver exploded, and I have no idea why. Current draw from the filter cap was not higher than 8A (8A fast fuse didn't blow) and the igbt's are rated at 40A cont. Anyway, I was getting up to 1' fat arcs from four flybacks before the driver died, here probably ends my hunt for the longest fattest arc from a ferrite cored transformer.
tongue
Sun Sept 23 2007, 03:34PM
Failures like that might be caused by a failure in the drive circuitry, I can't see an IGBT like that failing otherwise. If the gate signal sunk to low and the IGBT went into the linear range it would die pretty quickly. Did you take a picture of the monster arcs?
I put together a super flyback driver a few weeks ago, with over current detection, duty cycle control and the works. I had planned on putting four monitor flybacks in series, but I only got to two. In the process my oldest (and very first) flyback died. cry It was 2 years old, and had survived every driver until then. That marked the end of my flyback experiments.
Sun Sept 23 2007, 04:37PM
Uzzors wrote ...
My gate driver works fine after the failure, so this was not the problem (with a TC4452 for each IGBT, I think it's rather undestructible tongue ) . Sadly I have no pics of the arcs, the driver died just before I planned to take a video frown The failure was pretty violent, the fuse is completely black from inside tongue so I guess one igbt went short circuit for an unknown reason and the other one shorted out the power supply (clamp diodes are fine).
Update- one of the gate drivers was blown but I believe this was the result of the failure (gate voltage went too high/ outputting to short etc.)
