  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Iggy coil project
Spedy
Sat Oct 06 2007, 05:35PM Print
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
I've got everything I need, except for a power supply, a perf-board to get the dang thing neatened up, and a project box to put it in. I'm thinking a 12v wall-wart for the PS, but I can't seem to find an extra one. Maybe I'll find a couple of lantern batteries lying around....
See that knotted mess in the first pic? that's the circuit, and now you see why I need a perf-board really badly. :P
1191692108 964 FT0 Pa060025
1191692108 964 FT0 Pa060026
1191692108 964 FT0 Pa060027
Sat Oct 06 2007, 07:00PM
The flyback/ignition coil drivers using the 2n3055 transistor are floating around for many years, still using the same crappy transistor! They really should replace it with something better, nowadays there are transistors that will do the job 10 times better and are cheaper! (irf630, etc.).
Sorry I could not resist, every time I see a 2N3055 I must smile cheesey It was designed as linear regulator, it's not a HF switching transistor...
No offence intended, just play around with the circuit, observe it's performance, and replace the transistor. smile
Looking forward for the results,
J.M.
Sat Oct 06 2007, 07:27PM
Buy a breadboard while you're at it, it makes prototyping a dream.
Breadboard
Experimentonomen
Sat Oct 06 2007, 09:16PM
uzzors, there is a reason ppl use 2N3055, its cheap and readily available.
But yea i´d rather use lets say IRFP450, but with an iggy coil a high voltage igbt is also a good choice.
Spedy
Sat Oct 06 2007, 11:55PM
well, I don;t exactly have anything close to a budget, 6.50 a week isn't the shortest way to throw together $50 for an iggy coil driver, I didn't even have enough for the project box :\ I need bigger allowance.. or more patience. I just threw together a coil gun today, and I still feel like throwing together a rail gun and a ton of other stuff.... but I don't have any of the cash to do it with...
Sun Oct 07 2007, 12:30PM
You can't make everything you think of just get used to it. Or just save some money for one big project and do that one with a large budget.
