  • Guests: 39
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Dual diode question
Sat Aug 25 2007, 07:44AM Print
Just a quick question, is the 16A rating in this datasheet for both diodes conducting together or for only one diode? Thanks
Sat Aug 25 2007, 08:19AM
I believe it's for both diodes. In the datasheet the forward voltage drop is rated at 8 amps per leg, which I assume is maximum. I've noticed that they are pretty sneaky when specifying ratings for those diodes.
Are you building a bench supply? I just so happen to be working on one right now, and finding proper diodes at the right price is quite hard.
Sat Aug 25 2007, 08:30AM
Uzzors wrote ...
No, I just need some fast high current diodes for clamping in my igbt half bridge, one of the 9A ones I had previously, shorted out and took one igbt with it dead I'll just have to hope that 16A is enough... (its the only cheap diode in this range I can get)
Marko
Sat Aug 25 2007, 11:52AM
You need to be running something insane or have something really bad in the circuit in order to blow 9 ampere diodes from overcurrent. In that case it would be much better idea simply to get IGBT's with diodes.
In SMPS's they almost always use tiny diodes. Like 1 or 2 amps together with transistors rated for 300..400W of power.
Sat Aug 25 2007, 12:22PM
Marko wrote ...
I also don't quite know what killed them, but I think it was current spikes, I was running ca. 1kw of power (hard switching). The diodes did not get very hot.
As for the igbts, I have a limited source here and the ones I'm using are really cheap for their performance, though without a diode. I think I'll in the end buy several BY500's (cheap) and parallel them for higher peak current.
Edit- A NEW find! I get my components from Link2 , but just now I found the MUR1560 600V 15A 30ns schottky, for as little as 17czk ($0.80)! I'll put two in parallel on each "leg" of the bridge, this should be undestructible. smile
