  • Guests: 32
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Pinout required for old 10MHz RS Crystal Oscillator
Sun Aug 19 2007, 08:41PM Print
I have two old (1980's ?) RS 10MHz crystal oscillators that I need the pinout for.
They are RS 307-430, a 14-pin red plastic package.
Can't find via RS website or Google.
Anyone have OLD RS data?
mikeselectricstuff
Sun Aug 19 2007, 09:32PM
I've never seen an osc that didn't have the standard pinout - 0V pin 7,
+5v pin 14
O/P pin 8.
Occasionally enable on 1
I'd suggest applying 5V, via 100R to limit current in case its wrong, and scoping pin 8.
Mon Aug 20 2007, 04:39PM
Mike,
The crystal oscillator actually has all 14 pins,
as you say, pin 7 = 0V, pin 14 = 5V as usual.
There is no output on pin8 but on various other pins I find
two pins have a similar 10 MHz sinewave but clipped at the bottom
one pin has a nice 10 MHz sinewave.
One pin has +5 V on it.
Some pins seem to be at 0 V.
I vaguely remember there is a buffer onboard so I need to find the input pin for that
and one or more pins is/are for the trimming capacitor.
Guess I'll just have to poke-around a bit more.
