  • Guests: 33
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Dew sensor
Robert Mani
Thu Aug 16 2007, 07:19PM Print
Robert Mani Registered Member #799 Joined: Wed May 23 2007, 05:24PM
Hi all,
I am trying to build an electronic dew sensor for some device that can not tolerate water condensation. I have found one simple design that uses a resistive dew sensor element , an Op-amp as a comparator and an Opto coupler. Yo can find this design under the website:
However the resistive element is hard to find and I have found a store which carries the capacitive sensor.
My question is how would the circuit change if I use a capacitive element.I have already done a search on the net and did not find anything for the capacitive version.
Cheers
R.M
Thu Aug 16 2007, 07:38PM
Take apart any old VCR and you will find one.
A small white (ceramic?) rectangle with a black active area.
Usually on the capstan motor, if not look around - easy to spot.
thedatastream
Thu Aug 16 2007, 08:02PM
If you wanted to use the capacative sensor, you need to excite it with an AC waveform and put a capacitor in series with it to act as a potential divider. You can then rectify / integrate this signal and compare it with a reference.
I didn't know that VCRs had dew sensors in them - every day is a school day!
Carbon_Rod
Fri Aug 17 2007, 12:22AM
Condensation sensors (white/green/grey wafer in VHS VCRs) are not humidity sensors.
btw capacitive sensors are typically more sensitive, but have limited range (<95% non-condensing RH).
What is the intended application? Honeywell at one point made HVAC and instrumentation sensors. I forget who is licensed to sell their product line these days.
Bjørn
Fri Aug 17 2007, 03:55AM
What about using a normal cheap humidity sensor and a temperature sensor?
Robert Mani
Fri Aug 17 2007, 04:52AM
The application needs a condensation sensor, not a humidity sensor. I have to find a broken VCR to take apart!!
Some Thermoeleric cooler for a spectrometer is producing water condensations. The idea is to shut it off when this happens and produce some kind of warning signal.
I think Sulaiman's and data stream's ideas probably were to route to go.
Carbon_Rod
Fri Aug 17 2007, 05:06AM
Some people use a safe gas layer to prevent water condensation (Canned Air (non-cfc), Helium, or welding Argon). Perhaps something similar to the setup for CCD optics in telescopes may prove useful (encase all but the sensor window in epoxy.)
Fri Aug 17 2007, 06:12AM
If you need a true humistor there is one in an atmospheric radiosonde
you can get them on eBay very cheaply.
There's also a thermistor, a capacitive anemometer
and a water-activated battery.
Bjørn
Fri Aug 17 2007, 06:23AM
If you have the temperature and humidity you will know about potential problems before they happen and not after.
