  • Guests: 33
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Odd LED Display
Thu Aug 09 2007, 10:22PM Print
I've got a 7 segment LED display here with 4 digits, plus the decimal points and the colon. Thats a total of 33 segments. However, the display only has 13 pins. The numbers visible on the display are:
DL 4770
L8625P
3095
D
There is no manufacturer printed on it that I can see, and I've had zero success looking for datasheets.
Anyone got any ideas on how such a device is driven? I'm wondering if its got a BCD to 7 segment converter like a 7447 built in directly.
Dave
Thu Aug 09 2007, 10:45PM
I bet it's just a regular multiplexed display. 13 pins would be 8 cathode busses, 4 anode busses and one pin left for the colon. :P
If you're not familiar with multiplexing, play with it for a while using a 9v battery, resistor and a couple of wires, and you'll soon see how it's all wired up. There are two flavours, common cathode and common anode.
Electroholic
Thu Aug 09 2007, 11:35PM
Steve Conner wrote ...
sounds bout right to me smile
Capper
Thu Aug 09 2007, 11:41PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
Could be 4 X 3 binary coded anodes + 1 ground pin also. (3 bits for each 7 segment x 4 ) Post some pictures, maybe we can figure it out.
Scott
