  • Guests: 43
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Camera CCD question
Tue Aug 07 2007, 12:25PM Print
just a quick question, is it possible to damage/burn a CCD in a camera by capturing really bright objects? I want to film power arks to a wood, and where the arc touches the (already burnt/carbonized) wood, is a bright spot which causes vertical stripe to show up on the camera. I just want to make sure this is safe because the camera's not mine. Thanks
Tue Aug 07 2007, 04:38PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
Yes, you can damage a CCD with too intense a light source...like the sun or a laser. I am working on a time lapse project and burned out a CCD from sun glare.
Arcs on the other hand probably wont permanently damage the device.
Also many newer camera have circuits built in to prevent CCD damage from intense light sources (i.e. they blank out when pointed at the sun)
Do the streaks you see just appear on the cameras LCD view finder, or are they in the actual image when viewed on a computer?
The LCDs they use on cameras are very cheap and don't have a very high Dmax (density range) and they really wig out when they get too much signal - you can probably ignore it.
_SOME_ cameras have a "zebra stripe" effect that you can turn on to show areas that will be over exposed... if you see even black stripes on bright areas that's probably what it is.
Anyways, if in doubt you can use a 5 or 6 stop neutral density filter - that will attenuate the arc's light to a "safe" level for the camera.
also keep in mind the light from an arc follows the same rule as all light, intensity decreases as the inverse square of the distance. The further away you are the less intense the light. Even with a large lens if you're 20-30 feet back, zoomed in a bit, you should be safer than being 5' away zoomed out wide... you know what I'm saying?
Anyways, good luck, and post arc pics here when you're done :)
-Doug
Tue Aug 07 2007, 06:18PM
GreySoul wrote ...
Yes they're also visible on the computer
GreySoul wrote ...
I'm done now and camera seems to be ok smile , if you're interested here is a link to youtube video showing the arcs smile
CT2
Wed Aug 08 2007, 06:53AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
I noticed the stripes on videos of my tesla coil. The spark gap, that was made of different heat sink peices and copper would create the streaks, there was one streak for every gap. I have no idea what causes it... Even when the camera was not pointing directly at the gap you could still see the lines, for instance if your field of view was anywhere above the gap.
Thu Aug 09 2007, 05:39PM
CT2 wrote ...
Those stripes you see is what is called blooming. Its when charge from one pixel floods into an adjacent pixel and so forth . . . causing the stripes you see. This is typical of CCD sensors in which data is read out of each row in sequence as opposed to CMOS sensors which actually can read data from each pixel independently.
