  • Guests: 42
Damaged? Electrolytic Can Capacitor
Ian
Fri Mar 03 2006, 12:37AM Print
Ian Registered Member #62 Joined: Thu Feb 09 2006, 05:58AM
I just recieved 10 electrolytic can caps that i bought online they are 100v 4700uf, the problem is with just one of the caps if i shake it i can feel movement inside but the others (exactly the same) dont have any movement is this one a dud or just wierd?
Fri Mar 03 2006, 01:22AM
Doesn't sound good. I'd trash it and not risk it exploding.
Hazmatt_(The Underdog)
Fri Mar 03 2006, 01:23AM
might have gone dry. Do you have a Cx meter?
Ian
Fri Mar 03 2006, 01:35AM
My meter only goes to 200 i might try and get a replacement or refund.The guy said they were installed and never used but not sure what in.
EDY19
Fri Mar 03 2006, 02:23AM
I'd say put a 12V battery on it and see if it keeps a charge for a while, but I wouldn't go much higher voltage than that- it just sounds too risky to me,.
Omicron
Fri Mar 03 2006, 02:25AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
Toss it, It isn’t worth getting hurt over. Get your caps new at a supplier its safer.
Ian
Fri Mar 03 2006, 03:04AM
Getting caps in new zealand is hard enough let alone new ones.Although technically these are new.
Coyote Wilde
Sat Mar 04 2006, 03:33AM
Coyote Wilde Registered Member #175 Joined: Tue Feb 14 2006, 09:32PM
One dud from a surplus supply isn't that bad-- I mean, sure, it's 10%, but we haven't still established its status.
Do you have an o-scope? Should be simple enough to measure the capacitance at a well-derated voltage that way...
Ian
Sat Mar 04 2006, 05:38AM
No i have no scope but im being sent a replacement and im going to trash this one seeing as ill be running them at 280 volts in series.So please somone can lock this thread.
