  • Guests: 34
Michael Witt (36)
AleSeg (15)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
DRSSTC research project for school
Sun Jul 29 2007, 06:47PM Print
Introduction.
This is my first real drsstc that I'm going to build with a friend of mine. It will be used for a research project. For our school.
I'm hoping to use this topic as a build log and post some of my questions and hopefully receive some comments.
The research questions.
We have chosen the following research questions:
- Why do the arcs split up in forks?
- What determines the efficiency of a drsstc (max arc lenght min power (interuptor setting will be always the same))?
Some specs.
The coil is going to be based on Steve Wards schematic. Who else :P
The secondary coil will be 20 centimeter in diameter and 1 meter tall. And will be wound with 22AWG wire.
The primary will be made of 110 X 0.5mm aluminum sheet.
The MMC will be totally modular in order to research the impact on the efficiency (I already have 30 0.15uf 2KV caps).
The interrupter will be computer controlled because we need to trigger a camera as well. This way we can capture the sparks on film. Hopefully we will see a connection between on time and spark shape.
Updates.
MMC is finished
MMC
And the H-bridge is almost finished.
Th HbridgeComp
Here's the same topic, in dutch on an other tech (computer) forum Link2
Sun Feb 03 2008, 11:59AM
Updated
Electroholic
Sun Feb 03 2008, 04:55PM
i don't think you are suppose to put all the caps in the mmc in parallel.
Sun Feb 03 2008, 06:48PM
Electroholic wrote ...
They can be configured at random. The large screws are used to connect the cable so they aren't configured in as 30 parallel.
Sun Feb 24 2008, 03:31PM
I'm not completely sure which wire diameter I should use, is 22AWG wire ok for a 1 meter high, 20 centimeter in diameter secondary. Or is there a better choice.
