  • Guests: 39
Jyardana (41)
Gunboat (72)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
HV LED meter
Tesladownunder
Sat Mar 01 2008, 10:19AM Print
A quickie project as I wanted a meter I could read in the dark for my cap bank. (Never posted a project here before)
A commercial LED unit rated to 19.99 volts runs 5V from a 5v regulator from a NiCd pack. Input is from a 30kV rated handheld unit of 1000MOhm to 1.1MOhm. Meant to run 10MOhm load which the meter provides.
It is made in a "Heaven" coffee tin.
For what it is worth, I have a .01 cap and a neon bulb to bypass spikes. There is a coil on an unspecified toroid core in the input lead to the meter. Maybe it will help.
Meter is shown reading 13kV from my MOT supply.
TDU
1204366684 10 FT0 Hvmeterheavenlyrearopen
1204366684 10 FT0 Hvmeterheavenlyfront13kv
Sat Mar 01 2008, 10:51AM
Nice! this gave me some ideas.
What about a "bulletproof" frequency counter using optical fcounting through a small hole in the tin?
-A
Tesladownunder
Sat Mar 01 2008, 11:53AM
I think the fibreoptics would make a counter bulletproof if long enough. I have some and I planned to give it a go on my small TC. Worked on 5 different projects today so fairly busy.
For camera protection for my previous digicam and videocam I had a metal can about the size of a tissue box as a Faraday cage. For really close sparks I would use that but I don't have the equivalent for my SLR,
The LED meter reads reliably close to my analogue meter (perhaps 5%) to give some reassurance. The probe goes to 30 kV but I could extend that if needed but it really just was added to run my big cap bank at full capacity with remote monitoring.
TDU
