  • Guests: 48
IGBT tail current keeping SCRs on
TheMerovingian
Fri Jul 27 2007, 01:04PM Print
I got a problem on my multistage coilgun using 5 SCRs with a common IGBT on the cathodes.
When a stage fires the scr gate is biased positive respect to the cathode and the igbt is driven with 23V on the gate with a 3A mosfet totem pole bringing to ground the scr cathodes. Only the SCR with the gate biased positive turns off, the others remains in the off state even with a strong dv/dt. The pulse is regulated by a PIC16f876a. During turn off the IGBT tail current keeps the SCR on. So if a second pulse activating the igbt comes too early the SCR isnt fully turned off. These SCRs i use have a holding current of 18mA. Is there a way to fix this or i have to distance more the stages , or definitely stick totally to IGBTs (5 igbts for 5 stages)?
EN
Tue Aug 07 2007, 12:17PM
EN Registered Member #85 Joined: Thu Feb 09 2006, 01:22PM
I have encountered similar problems with my hybrid switching CG but in my case i believe the problem lies with the SCRs themselves, not the igbts. Usually, the Tq of SCRs will be much higher than the Tt of IGBTs. In my case 110us. So it might be possible that in your case the bottleneck is also the SCRs, and that you could solve your problem with ultra fast SCRs with a lower quench time.
TheMerovingian
Tue Sept 18 2007, 01:25PM
decided to stick to a classic switching with 5 igbts. the problem will be the space for the drivers (discrete)
