  • Guests: 30
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
IC substitution: RS7474N for MC74HC74?
Wed Jul 25 2007, 05:21PM Print
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
Does anyone know what the HC designates in an IC? I have a drawer full of RS7474N DIP-14 D type + edge triggered f/f's I'd like to sub in a circuit that calls for the 'HC' variety. (MC74HC74).
My limited understanding is that most ICs with the same numbers vary little in function from manufacturer to manufacturer, but it certainly can make a world of difference when characters are added - no matter how minor, right?
Anyone able to enlighten an inquisitive mind?
-Doug
Bjørn
Wed Jul 25 2007, 05:36PM
If my memory does not fail it stands for High-speed CMOS. That means that the input and output voltages are different (among other things).
A 74HC74 should be able to drive a TTL chip but a TTL chip can't drive a HS chip since the TTL chip does not have high enough output voltage. You might get by with a pull up resistor in some cases. A 74HCT74 will on the other hand be voltage compatible with a TTL chip.
Try this page: Link2
ShawnLG
Wed Jul 25 2007, 05:38PM
The HC means CMOS version of the TTL family of chips.
This site should clear all that up.
Wed Jul 25 2007, 06:49PM
Ah, excelent. I'm going over to my dads to steal all his IC ref. books....
Thanks a ton, I'll post the outcome of all this in a projects thread soon enough... building a Minibrute DRSSTC :)
I guess I'll hit the surplus shop and search for some HC74s
-Doug
