  • Guests: 32
Billybobjoe (35)
07/19 Thomas (40)
07/19 VulcanBB18 (50)
07/20 rev (49)
micro camera and lcd screen
Fri Jul 20 2007, 02:57PM Print
I am thinking about making a device to observe tissue structures in the mouth using a micro camera that would be attached to a small (1-2" square) LCD screen. I've started searching for sources of parts but I am not finding what I want. Does anyone know any sources for micro cameras (not wireless) and LCD screens? Any good sources for pre-made video processing units so I don't have to start soldering board?
Fri Jul 20 2007, 03:05PM
On eBay there are things like this Link2 or Link2 or Link2
Fri Jul 20 2007, 04:02PM
I would definantly recomend an endoscope, as even the smallest cameras out are still well over a 1/4" in diameter... As to the LCD, I do not know of any commercial sources, but you usually can usually use the viewfinder from a videocamera with a normal composite signal, you just need to probe arround on the board for a while to figure out where to feed it in.
Fri Jul 20 2007, 05:27PM
I am trying to find a source for the parts as I want to develop a device for my medical field. I can't use existing scopes and devices.
Fri Jul 20 2007, 06:47PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
Fri Jul 20 2007, 08:38PM
Don't forget that you will need some form of illumination also.
Is this Link2 more what you want?
Simon
Sat Jul 21 2007, 01:18AM
Jaycar sells pinhole cameras that are around the sizes of coins. Things like that aren't hard to get. I can't say anything about LCDs.
Do you really, really need the camera inside the mouth?
Sat Jul 21 2007, 02:33AM
Medical companies already have devices for scoping body cavities. I want to try and "build a cheaper mousetrap."
I understand there are other items I will need, but right now I am specifically looking for the raw parts to I can capture a video image. I need a fiberoptic cable for the end, a camera to get the internally reflected image and a video processor and screen. This all needs to be hand-held. I need the raw parts because I want to be able to assemble this cheaply and fit it to an illuminated medical device. A pre-packaged "spy-camera" will not work.
I am sure there are sources overseas but I don't have any connections which is why I made the initial post.
thedatastream
Sat Jul 21 2007, 08:21PM
I remember reading about this ages ago on the BC News website - Link2
