  • Guests: 18
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Astronomical mystery
Bjørn
Fri Jul 20 2007, 02:01AM Print
I got this bright light on some pictures, it was just about visible to the naked eye. It was in the middle of the day and within 45 degrees of the sun. It seemed to have a constant brightness for more than 30 seconds until I lost it.
Any good ideas what it is?
ISO 250
1/350 s
F/10
150 mm
Fri Jul 20 2007, 02:56AM
Some of the iridium flares can be bright enough to see during the day...
kv
Fri Jul 20 2007, 03:15AM
kv Registered Member #809 Joined: Wed May 30 2007, 08:59AM
i saw somehting like that a while ago, i found out it was a sattelite reflecting the sun cheesey
Bjørn
Fri Jul 20 2007, 04:23AM
Since the brightness was constant it does not seem like an Iridium flare. I tried Heavens Above but it is pretty useless at finding flares in the past.
Chris Russell
Fri Jul 20 2007, 06:30AM
Chris Russell ... not Russel!
Bjoern, if you can provide a date, time, and an approximate position in the sky (heading and elevation), I may be able to figure it out.
Bjørn
Fri Jul 20 2007, 07:31AM
The EXIF says 2007-06-27 16:02:27, including daylight saving it should be two hours ahead of UTC.
I did not have a compass but it was to the left of and below the sun. My guess is a heading of 205 degrees and an elevation of 40 degrees.
cbfull
Fri Jul 20 2007, 12:07PM
I have seen high altitude jet planes reflect sunlight briefly like that. Once it stops reflecting you can sometimes see the shape of the object that reflected it.
Fri Jul 20 2007, 03:46PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
cool, a real UFO. For the time being, anyways.
Chris Russell
Fri Jul 20 2007, 05:07PM
Assuming you were at your home location as marked in your profile, I did not find any candidate satellites for June 27th, 2007, ~1400UTC. There wasn't much activity in that part of the sky, as far as normally visible satellites, and the few that were there aren't that bright, and have distinct signatures, such as a regular flashing period. The duration and constant brightness would seem to discount an Iridium flare, and the fact that there were no Iridium satellites in that part of the sky at that time would seem to verify this. Unless the location and/or the time is wrong, I think it will remain a mystery.
Fri Jul 20 2007, 08:43PM
what you saw was swamp gas that reflected light from venus
