  • Guests: 29
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Adequate Filter capacitance?
Danielle
Thu Jul 19 2007, 04:06AM Print
well I had 4 450V 2400uf caps and I needed a new filter on the full bridge doubler so I built this I am wondering at 900V 2400uf cap is enough I will be running it at doubled 120 AC so 340VDC Also if the copper bus bar construction is adequate? This is for a full bridge DRSSTC that I have been working on.
also latest pic before the filter caps blew up of my DRSSTC
thanks,
Daniel
1184818001 632 FT0 Img 0473
1184818001 632 FT0 Img 0474
1184818001 632 FT0 Img 0468
edit
do I need an inrush current limiter or is it ok if the lights dimm?
EDY19
Thu Jul 19 2007, 04:34AM
Why did you series the capacitors? IT seems like 330V on a 450V capacitor would be fine, and if they were all in parallel, the ESR would be lowered.?
Danielle
Thu Jul 19 2007, 04:50AM
true but I need a voltage doubler I was thinking of running it off the 240V line but I didn't want to go through the trouble of always getting to one of those outlets I only have 2 in my house.
EDY19
Thu Jul 19 2007, 05:14AM
So these capacitors make up the doubler? That makes a bit more sense smile
Danielle
Thu Jul 19 2007, 05:43AM
ewll toolate I decided to re build it to run off the 240 line and then I get 450V 10,000uf yah Im using 1" bus bar now
Thu Jul 19 2007, 03:28PM
All 4 caps are probably overkill for the size of IGBT you are using, but they should be adequate in either doubler (2400uF) or all parallel (9600uF). Keep the wiring between the caps and the IGBTs as short as possible. I try to integrate the cap's bus wiring to the IGBT wiring so there are at most a few inches of wire between the two.
Danielle
Thu Jul 19 2007, 08:35PM
here is how I made it I am almost done I just need to mount the components on the other half bridge witch will come in tomorrow via UPS so I should be able to have it done by Thursday because I need to build a larger box to house everything. Dose everything look right from my pics I tried to minimize inductance.
1184877315 632 FT28617 Img 0476
1184877315 632 FT28617 Img 0477
Thu Jul 19 2007, 10:07PM
Surely you can reduce the length of the bottom right buss bar. Use thin plastic as insulation between the copper bar and the PCB where necessary. Its not good to have the bus bar routed so far out of the way. The left side looks very good.
Of course, those caps are wired in series/parallel (instead of just parallel like you said you were going to do) but they should still be fine, and could be used for a voltage doubler still.
Danielle
Thu Jul 19 2007, 10:36PM
I will try to re route the long bus bar after I mount the heat sinks then I will know where to leave open. Also the caps are going to be used as a voltage doubler otherwise I would have had then all in parallel.
Thanks,
Daniel.
Danielle
Thu Jul 19 2007, 11:06PM
here is how I mounted it I think it is adequate the CPU cooler mounting holes will be covered by some plastic I found at the bottom of a computer PSU.
1184886384 632 FT28617 Img 0478
