  • Guests: 49
Killa-X (34)
Luca (45)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Peltier Controller
Eric
Wed Jul 18 2007, 06:04PM Print
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
I want to build a peltier driver for closed loop temperature control of a diode laser. I want to use the first part of the circuit shown on page two of this doc (the op amp integrator) but I need to figure out how to convert that error voltage into a drive current for the Peltier. An easy matter for most of you I'm sure. Any ideas on what would be simplest? The driver stage needs to supply ~1.5A tops at 5-7V.
I'm not interested in using the MAX8521 driver just because I've never worked with SMTs before...
IMG 2227
Ghetto laser cooler
Ken M.
Wed Jul 18 2007, 09:44PM
I would imagine you could use a gate driver chip such as a 4429,20,27, ucc those kinda drivers, but only supply it with 5-7v's and from what I've heard peltier coolers, chill soo much air that they create condensation.
Thu Jul 19 2007, 01:04AM
Funny this should come up, I just wired a dev board using a very similar chip into the project we were working on--but of course I reversed the +/- so if fed 5v back into the Tset pin angry But it was my boss who decided that it was probably the motherboard that was broken, so he goes and plugs it into another system wink
In any case, the output stage you need will depend on how much temp regulation you need. Since you aren't trying to hold the wavelength to +/- 2.5 GHz (or well under a GHz in my case), and you don't have to warm the diode, you should be able to get away just using a comparator on the output of the integrator, feed him into a mid sized MOFET, and call it a day.
Thu Jul 19 2007, 01:16AM
Something like this
1184807293 162 FT28586 Tec1
any op-amp will do that has enough output current to drive the transistors
The two transistors should be able to handle the maximum TEC current, power etc.
they could be simple power bjt, or darlingtons, or complimentary mosfet etc.
R1 senses the TEC current, so to match the +/- 1.5 V in for +/- 1.5 A out, it should be 1 Ohm (2.25W actual, use a 5W resistor)
R2 is not really required, it's to protect the TEC against over current, you could put a 2A fuse instead
If more specific design is required ask again.
Eric
Thu Jul 19 2007, 01:53AM
Thanks for the suggestions guys, Sulaiman that looks very good. I was just thinking of using a FET or emitter follower but wasn't sure how to get feedback to translate the error voltage linearly into a TEC current. Very simple.
Thu Jul 19 2007, 08:47AM
I've designed a few commercial Peltier drivers for laser temperature control, and the linear ones used basically an H-bridge version of Sulaiman's circuit. The reason for using an H-bridge was so I could drive the TEC current in either direction while running off a single +5V rail.
My old employers sell very nice and cheap laser and TEC drivers designed by me smile @ Link2 Link2
Marko
Thu Jul 19 2007, 12:32PM
You couldn't afford four more screw-pedestals to make it more stable? cheesey
Nice LD rig Eric.
If it was me I would probably go for a PWM regulator like SG3525 or TL494. This is easy, since peltier is resistive load and all you need is a mosfet to switch power into the peltier.
Frequency does not need to be high either.
Then I would simply use the chip's error amplifier with NTC to do the temperature sensing job.
You can as well use error amplifier in linear mode as sulaiman suggested, but that results in lots of wasted power making it more complex than PWM. Few watts is still quite hard to get rid off in miniaturized system.
Surely this is all ghetto and if you want something calibrated or digitally adjustable better go for microcontroller or that maxim IC.
Error amplifier will always ''take care'' to equalize it's inputs, so mosfets will work as well.
It's just the matter of some more dissipation.
Bjørn
Thu Jul 19 2007, 12:46PM
Peltiers does not behave completely like resistors and don't like ripple very much. So for PWM you need either very low frequency or high frequency with a filter to remove the ripple.
Eric
Fri Jul 20 2007, 08:18PM
Firkragg wrote ...
Nice LD rig Eric.
Yeah, I thought about using a PWM but I've actually never built a PWM circuit, I thought a simple linear setup would be best, it's just a couple watts of loss... I may just try it though. The more I think about it the more complicated I'm making it.
It may be ghetto but I should be able to get nearly as good results as a nice integrated PWM. I bet +/- 0.01C is doable. I'll post what I end up with in case it's of any use to anyone.
Marko
Sat Jul 21 2007, 12:12AM
Hi guys
I don't know about ripple problems with peltiers.. never heard about it. What mechanism could cause them 'not to like ripple too much'?
From here Link2 I assumed they can be PWM'ed. Ofcourse, it is done at low frequency, in range of low hertz, just to satisfy your desired temperature resolution.
Regarding ''high frequency PWM with a filter'', such a thing is called buck converter.
Eric could even use one of those fully-integrated buck converter IC's like LM2575 and use NTC resistor feedback instead of output voltage.
But, what I actually feared is that too low DC voltage may trouble the peltier more than
direct LF PWM, where it always gets it always gets it's working voltage or 0V.
