  • Guests: 32
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
simple audio modulator
Danielle
Fri Jul 13 2007, 09:33PM Print
will this work for a simple audio modulator to use into an OCD DRSSTC it would be nice to know so I can have it ready for tonight.
Thanks,
Daniel.
1184362426 632 FT0 Mod
Ken M.
Fri Jul 13 2007, 09:38PM
It looks like it would\might work, I'm no expert on audio circuits, if all else fails and you aren't expecting HD audio, just use a simple npn single transistor amp.
Danielle
Fri Jul 13 2007, 09:40PM
ok thanks ill try it out with lots of current limiting at low voltages first if it works
ShawnLG
Sat Jul 14 2007, 07:13AM
I would put a DC blocking capacitor on the input and small pull up resistor on the (+) to help keep the trigger off when there is no audio being fed.
Sat Jul 14 2007, 11:58AM
The problem is the lack of proper duty cycle control. Not only that, but your circuit should really have about -1.5V bias on the -V pin. Otherwise, your audio signal might need to be 1V or more to actually trigger the comparator (and normally it isn't such large amplitude). Also, you dont want to try and play too much musical "data" at once on a DRSSTC. It sounds best as a "monophonic" device, so only 1 note (dont try to play a normal song through it, it will sound bad).
Have the comparator output trigger a 555 timer to give you a specific output pulse length.
Danielle
Sat Jul 14 2007, 05:05PM
is there a simple whay to create the negative voltage bias I finished the 555 integration and will post updates soon but I don't understand of an easy way to create the negative bias voltage.
edit
here is the updated schematic, input is greatly desired.
1184435129 632 FT1630 Adio
how small is small for the input pull up resistor around 1K
Thanks,
Daniel.
Myke
Sat Jul 14 2007, 06:55PM
Looks cool. What would be the resistor between pins 8 and 4 on the LM311. I would like to build one if it works because it would be nice to have.
Danielle
Sat Jul 14 2007, 07:08PM
its still a work in progress I wouldn't build it yet I am trying to figure what would be best there and how to create a neg bias.
Danielle
Tue Jul 17 2007, 04:07AM
ok so here is a audio file I recorded of the output of the modulator of the super mario theme you can barely make it out but you can see the square waves with an audio editing program it has so much distortion I need help working out how to remove it.
]1184645224_632_FT28344_adio_interupter.mp3[/file]
Myke
Tue Jul 17 2007, 05:31AM
It's good (yeah you can filter out the distortion though by ear). It's not super Mario it's Tetris. wink
