  • Guests: 29
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
The Radio Shack special.
ShawnLG
Thu Jul 12 2007, 06:32PM Print
This FM circuit looks to simple to be true so I decided to build my self to try it. It worked better than the FM radio I built a while ago using an FM IC using 7Mhz filter network, mixer and all that complex stuff.
Link:
I used a single loop antenna as the drain coil and used a Varactor diode for tunning. This worked better for me. To eliminate the construction of the source coil, use a standard 2.2 or 3.3 uH inductor.
1184265129 286 FT0 Rs Special
