  • Guests: 31
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Test bench feedback
nrhoades
Sun Jul 08 2007, 04:11AM Print
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
To wet my whistle and begin experimenting with power switching, I decided to build a simple H-bridge test bench to run at low power. Key point: I have never designed a switching power circuit before. Hopefully this will provide me with more "working" knowledge of this stuff in addition to theoretical knowledge that I "think" I have. :) For now, the voltage seen by the load will be less then 100V.
What do you think?
1183867364 610 FT0 Schematic
As a tangental question to this post, I have noticed that many/most people here use GDT instead of chips. I am assuming that because tesla coils are a huge object of interest, the GDT provides the most isolation. I suppose they work fine and are robust for resonant circuits, but wouldn't one lose control over the waveform if they wanted to change the duty cycles and dead-time of the switching (as compared to a LO and HI side driver chip?)
Carbon_Rod
Sun Jul 08 2007, 07:10AM
Most of it looks pretty standard,
I have been trying to find a cheap surplus 50kWatt bridge from a NHW20 Prius to add to the bench.
No luck as of yet....
Sun Jul 08 2007, 07:38AM
GDTs work fine with PWM. Just make sure you drive them properly, otherwise stuff like this happens.
1183880329 95 FT28033 Dsc00199
Marko
Sun Jul 08 2007, 02:03PM
What do you think?
I think nothing because you provided almost no information about what are you trying to achieve.
Full schematic would also be good.
GDT's have no problems with deadtime. All they want is constant volt-seconds over and under zero, and that is assured by your PWM controller and DC blocking capacitor.
Those IR chips look like a waste of money to me. They are useful but only in special occasions like low frequency or non-symmetric drive.
Sun Jul 08 2007, 02:24PM
Well, if you want to play with other H-bridge applications like Class-D audio amplification or motor control, you're going to need that "low frequency and non-symmetric drive". I have a couple of boards with Toshiba TLP250 opto-isolated gate driver chips, that I would use for situations like that.
