  • Guests: 41
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Big DRSSTC
Crow187
Mon Jul 02 2007, 10:14AM Print
Crow187 Registered Member #795 Joined: Mon May 21 2007, 06:04PM
Hi there, I'm new to this board, and I want to present what I am working on.
I had the possibility to use IGBT halfbrige-bricks rated 600A and 600V with 1200A pulsed. So I decided to build a big DRSSTC. I use 4 of these (2 in parallel) to bulid my fullbrige. So I have 2400A pulsed current rating of my bridge. I designed the control electronic by myself, and wounded a PVC pipe with a diameter of 40cm, total hight 1.75m with 0.75mm wire.
Perhaps a bit oversized, but I liked to build this big coil =)
The topload is just temporary like you can see on the pictures, I ordered aluflex, so soon it will be much nicer ;)
I have still to do a lot.... At the moment: Lacquer the sekcoil, peakcurrentdisplay, toroid and primarycoil have to be rebuild...
I get sparklengths to 1.70m, but the bridge is still keeping cool, and it can take much more, I will test that the next weeks.
Here a picture of the bridge:
IMG 4634thumb
And here a picture of the pipe:
IMG 4748thumb
And here two sparkpictures:
IMG 0125thumb
IMG 1806thumb
On my website are more detailed infos (only in german, sorry), pictures and videos: Link2
I hope that i will get 3m long sparks soon ;)
If there are new infos of this project I will post here!
Lukas
p.s. sorry for my bad english
Mon Jul 02 2007, 10:25AM
Welcome - That's quite a first post!
(much better than the usual first post of "Who can give me plans for an EMP bomb?"!)
Looking at the 'scope shot on your website;
It seems that the effective primary resistance is providing output current limit
(the envelope of the ring-up flattens-off)
So I guess you could use the IGBTs in a full-bridge if required.
Looks like some major ozone layer replenishment is due!
Great stuff !!! Keep us updated.
Crow187
Mon Jul 02 2007, 10:37AM
Sorry, I wrote halfbridge, but i wanted to write fullbridge! These bricks are a halfbridge each, and i put 2 in parallel for each side of the fullbridge.. I corrected it in my first post.
You are right, the primary is (like a lot of things) just temporary, copper tube is ordered to build a nice one!
Lukas
Crow187
Fri Sept 07 2007, 01:26PM
Hi there!
I just wanted to update my Projekt.
Sparks are now more than 2 meters long... The only limit is now the powersupply, the H-bridge can make much more...
Here are a few pictures.
crow187
1189171541 795 FT27625 Photo1
1189171541 795 FT27625 Photo2
1189171541 795 FT27625 Photo3
Sat Oct 06 2007, 04:29PM
That's some brute power you've got there. I never get it where some people get the money from to build such cool tesla coils. Could you share the schematic of the control electonics?
Crow187
Tue Nov 06 2007, 12:10PM
Yes I can post the scematics if I can find them! =)
I will search and post if I find them...
In two days I will make another testrun on this coil and hope to get 2.5m sparks.
bye
Crow187
Fri Nov 16 2007, 12:40AM
An update for my project! Today we tested some new things (like a new toroid again), and it was really successful.
A few hits into the ground were about 3.6m away from the outpreak-point! =) The fotos I post now don't show that long sparks, but I will post them tomorrow.
The upper picture is color-corrected with PhotoShop, and a 4s exposure.
Have fun with the pictures!
p.s.: We allways blew up the 32A 3-phase powerline when the coil was running at full power and hit the "target"!! fun ;) So these pictures are NOT at full power!
Lukas & team!!!
1195173326 795 FT27625 Img 5219 Kopie
1195173326 795 FT27625 Img 5177
Crow187
Fri Nov 16 2007, 01:47PM
Now here are some "ground-hit" pictures!
These are all about 3.20m or 3.30m distance from outbreakpoint.
The pictures at the bottom show what happens if a plant is hit ;)
Now I will rebuild my electronics (IGBT driver, and main electronics). After that I will eventually increse the voltage on the bridge.
Perhaps I will have 4 meters soon?!
Hope you like my coil, don't you?
Lukas
1195220736 795 FT27625 Img 5294
1195220736 795 FT27625 Img 5285
1195220736 795 FT27625 Img 5293
1195220736 795 FT27625 Img 5241
1195220736 795 FT27625 Img 5244
1195220736 795 FT27625 Img 5245
1195220736 795 FT27625 Img 5248
Fri Nov 16 2007, 03:48PM
Now that's truly impressive. Those ground strikes almost look like a plasma torch. Hope you'll hit the 4 meter mark soon. Where did you get those igbt's from?
Crow187
Fri Nov 16 2007, 04:52PM
I build this coil in our university, and the IGBTs were inventory of a laboratory. The university gets electronic components from a company wich the university cooperates with... When they are developing something and parts are not used, they give them away (most to us) after a period of time...
So it was just luck that we had IGBTs like that! =)
