  • Guests: 49
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
PWM light thingy
Zum Beispiel
Thu Nov 22 2007, 02:36PM Print
Here's something I've been working on and off for about a year.
1195740724 514 FT1630 Lightbluelight2
It's a RGB led light that is controlled with PWM. It can be set to any color with the three pots in the front panel.
Here's a view of the innards. The PWM driver is bolted to the rear panel, transformer and voltage regulator on the floor. Diode bridge is made of 4 1n4007, soldered together and the smoothing cap mounted on top of it cheesey
1195740724 514 FT1630 Pwmcontroller
Light source is a 1W RGB led. Though I'm only driving about 80mA into the diodes ATM... The only suitable transformer I had was a 15V one, and if I drive the diodes to 300mA each, things start to get toasty. I'll have to get a new transformer...
Top and bottom sections are made of low density polyethylene, front and rear panels of PCB laminate and the mesh was ripped from a dead speaker.
Next improvements after replacing the transformer will be making the top out of plexy so more light can escape and using mesh with larger holes.
Pictures:
1195740724 514 FT1630 Green
1195740724 514 FT1630 Gold
1195740724 514 FT1630 Pink
1195741955 514 FT1630 White
Thu Nov 22 2007, 07:49PM
Useless, but sooo cool. shades It looks great, you should try selling them.
Shaun
Fri Nov 23 2007, 03:55AM
I wonder exactly what percent of the things we build here are NOT useless...lol.
Tom540
Fri Nov 23 2007, 08:46PM
Tom540 Banned on 3/17/2009.
Looking cool isn't useless. It's art. Put it into a computer case.
Avalanche
Fri Nov 23 2007, 09:16PM
That's actually quite nifty!
Now all you need to do is make 3 bandpass filters, with passbands that correspond to 3 audio frequency ranges for 'bass, mid and treble'. Use those outputs to modulate the 3 PWMs, and you have a 'music to RGB converter' cheesey
EDY19
Fri Nov 23 2007, 11:24PM
Avalanche- I like that idea!! That could be really cool! I say move forward and do it cheesey
Avi
Sun Nov 25 2007, 10:37AM
oh, i did a similar thing from my computers parallel port and a RGB led and i could set the pwm of each with on screen sliders
Zum Beispiel
Sun Nov 25 2007, 06:29PM
Avalanche wrote ...
Hmm, that is actually a really good idea. I'll have to look into that when (if) I get some more spare time. Won't be easy, though. With two new SSTC's and tons of other projects in the works and all angry
