  • Guests: 31
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
SMPS modding?
Tue Jun 26 2007, 10:15PM Print
Hi all,
I have an LG flat panel TV here where the SMPS has blown in an expensive and hard-to-repair way due to the set being dropped.
Before I waste any more time on it, one thing I'd like to try is powering the various rails manually using an array of separate supplies.
Main problem is the 24V 4.5A rail, nothing I have is even close *except* an HP printer supply.
This is 31.5V at 3.4A
I've taken the supply apart but modifying it for 24V use is proving difficult. Both zeners seem to do nothing apart from shut it down if removed or swapped for a different voltage.
went on a hunt for resistive dividers or regulator ICs but a lot of the circuitry is buried under that damned unremovable white snot-like glue :(
Any ideas? it doesen't have to work for long :)
thanks..
-A
BTW its an LG TV if that helps.
Carbon_Rod
Tue Jun 26 2007, 10:47PM
Hmmmm... ponders the 4hv rules about schematics.... o well...
Google LM317 regulator based power supply with a 3055 or similar current multiplier...
Depending on the make it can handle up to 26.5vDC and some designs can provide a steady 5A supply...
IIRC some folk here have modded old ATX power supplies too...
Wed Jun 27 2007, 09:38AM
Without knowing the PWM IC type modding wil be hard. Your best bet would be putting an external regulator on it like Carbon_Rod suggested, or modding an ATX/AT supply. Our very own thedatastream has a good guide on AT supplies, and I have one on ATX supplies.
Wed Jun 27 2007, 09:56AM
Two car batteries in series :P
