  • Guests: 24
Sonic (59)
kamelryttarn (47)
11/30 arnsfelt (46)
11/30 jaysun92 (33)
12/02 Hax (40)
Question about Checking HV Diodes
Matthew T.
Wed Jun 06 2007, 03:31PM Print
Matthew T. Registered Member #513 Joined: Sat Feb 10 2007, 07:30PM
I have recently performed an autopsy on my dead CW multiplier. Hoping that only a few of the diodes died, I began checking them with my mm. I am not able to successfully interpret the results. What should be the resistance reading of a hv diode? My average results:
- to anode + to cathode : 100 to 300 kOhms
+ to anode - to cathode : 0.6 to 3 MegOhm
cheers,
Matthew
Wed Jun 06 2007, 03:54PM
It is hard to test diodes by measuring resistance, as they do not have any resistance by rather a fixed voltage drop. Some meters have a seting that can be used to measure that.
If not, grab a resistor (1k would be fine) and put in in series with a 12v (or w/e) supply. Put the diode in across the resistor/gnd and measure the voltage across it. One way should read about a volt, the other way should read 12v.
If it passes that it is probably good, but it could still be damaged...
Wed Jun 06 2007, 04:06PM
hv diodes are usually constructed using many single diodes in series so you might need higher voltage to test it
Wed Jun 06 2007, 09:31PM
As Jmartis said HV diodes do require higher voltages to get current to flow in the foward direction. Connect a current-limiting resistor in series and increase the voltage and have a current meter in series.
Tesladownunder
Thu Jun 07 2007, 04:09AM
You also need to uderstand why you blew the CW muliplier or you will do it again. I use a resistive load in series with any sparks. Also you need to be sure you are using appropriately rated diodes. If you are runing from 1kV AC you need diodes rated at minimum 2.8kV. Like a microwave oven has 2kVAC and uses 11kV rated diodes.
What are the details of your multiplier and driving voltage?
TDU
Matthew T.
Thu Jun 07 2007, 01:30PM
... : Thanks alot!. I tried this method and it seems to work. Only surprising thing is that in all of the diode ( 40 total) only 4 or 5 are dead. Would this dramatically affect the performance of a 10 stage CW multiplier? I will try putting it back together without the dead ones (less stages) and see the results.
Tesladownunder : thanks for your reply. All the details of the multiplier are in this post : Link2
Matthew
