  • Guests: 33
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Electronic circuit simulator?
noobletmonger
Wed Jun 06 2007, 01:40AM Print
noobletmonger Registered Member #683 Joined: Sun May 06 2007, 02:00AM
I would like to know what electronic circuit simulator is best for general purpose use. More specifically, however, I am going to build the boost converter described in this topic. Since I have almost no experience with electronics, I will need to test out the circuit before I get all the parts. Is there some type of program that can do this?
Thanks! smile
Carbon_Rod
Wed Jun 06 2007, 04:17AM
NI's Multisim is easy -- student edition is sill pricey,
CT2
Wed Jun 06 2007, 04:20AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
B2 Spice is what I have, you only get a trial version (well at the start its not but after 30 days or somethign it is). Still though the trial version is decent enough for small circuits.
Bjørn
Wed Jun 06 2007, 04:33AM
This shareware program is reasonable: Link2
Remember that simulation and reality is not the same. Many circuits that work fine in reality will fail to simulate in Spice. If you keep adding parasitic imperfections it usually starts working at some point.
Simon
Wed Jun 06 2007, 04:37AM
SwitcherCAD is passable and free.
thedatastream
Wed Jun 06 2007, 06:46AM
I use SiMetrix Link2 at work and at home
James
Myke
Wed Jun 06 2007, 01:32PM
I use CircuitMaker. Link2
Wolfram
Wed Jun 06 2007, 03:01PM
Last time I used multisim, it was very hard to use and not very good at all. That was a couple of years ago though.
How about Proteus (Link2)? I've never tried simulating analog stuff in it, but for digital stuff it blows everything else out of the water. It can simulate ARM microprocessors running linux and it can run a virtual web server on an ethernet PIC that you can connect to through the ethernet port of your PC.
Ken M.
Thu Jun 07 2007, 04:54AM
Multisim works but too much work for little results, I use Tina, it has some issues but works for most anything. The one big problem that I haven't figured out is how, or if even possible to combine digital and analog circuits. Eitehr way heres the link Link2 I have Tina pro version 6.
noobletmonger
Thu Jun 07 2007, 10:53PM
Thanks for all the replies! I will have to try out some of these! cheesey
