  • Guests: 62
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Scaling up the joule thief
TheMerovingian
Thu May 31 2007, 11:24PM Print
Since the joule thief is very good boosting the voltages even lower than 1V (as voltages got from fuel cells) and it is essentielly a self oscillating boost-converter, cannot it be used to step voltages at higher powers (around 1-2 watts). Using a high speed BJT, a big base resistor, a bigger core and a schottky barrier diode. THe purpose is to step up lower voltages got from an eolic alternator (3-6V at 1.6Ohm) to 13V to charge a small SLA (1AH). The normal control circuits cannot go under 6V for driving converters, and i don't need regulation (the battery regulates itself). Any suggestions. Using a gapped core should be ok in this type of designs or not?
Thu May 31 2007, 11:33PM
germanium power transistors arranged in a royer-like circuit? :)
might even work with an NPN/PNP pair with some modifications.
-A
Fri Jun 01 2007, 12:33AM
First I'd have a look inside the generator,
IF it's an alternator with rectifiers it may be better to use the ac direct from the alternator via a step-up transformer.
If it's a dc permanent magnet type with commutator then some kind of invertor is definitely required.
I'd imagine a boost converter based on something like an LM2588 'simple switcher' would be quite good.
Electroholic
Fri Jun 01 2007, 05:29AM
if its gonna be charging the sla, why can't you get power from it?
thedatastream
Fri Jun 01 2007, 06:30AM
You could use a Joule thief to provide the power supply rail for a simple low power boost converter IC and have the actual input to the boost from your alternator.
TheMerovingian
Fri Jun 01 2007, 09:29AM
It is a single phase alternator. Stepping up the voltage using a transformer needs a bigger transformer that would be at that power rating (the frequency is in the 25-40Hz range), but it would work. The idea is to use the joule thief to power a control circuit or a pair of mosfets in a royer type circuit. What type of core can i use?
lamazoid
Sat Jun 02 2007, 01:46PM
lamazoid Registered Member #573 Joined: Fri Mar 09 2007, 11:26AM
Since you dont need high voltage out, you can use simple boost converter ICs, like mc34063 or something. MAXIM provides a lot of them.
In the case you want to use exact "joule thief" circuit, try it with small E transformer, it should give 1-2watts but efficency will be low, until you find some text book about "blocking oscillator" and calculate one for your needs.
