  • Guests: 29
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
TL494 output stage headaches
Thu May 31 2007, 07:42PM Print
I've been trying to get the output stage of the TL494 under control for so long. I made an output stage a while ago which preformed well, and I thought I had finally conquered the TL494. But when I put it in a smps today the primary drive transistors heated excessively. I tried swapping the 15k base resistors with 180 ohm ones, but the heating just got worse. Within 5 seconds the transistors where near 100 degrees. I haven't needed basic electronics help for a while, but now I need it bad, the TL494 headache has got to end. Has anyone successfully used a TL494 + PWM + non-centertap GDT? Ever? Because I've only seen it done once before, and involved a complicated system which I never understood. To top things off I threw in the towel and bought one SG-something or other, the type with just two outputs that can be connected directly to the GDT. But one of the outputs had died somehow, so all I got was a single sided pulse! mad Could somebody please help me!
1180640536 95 FT0 Tl494 Pwm Gdt Driver Mkii
Thu May 31 2007, 08:10PM
To me it seems that your PNP transistors never turn off... Try to put your 15k resistors in bases of both your pnp and npn transistors, not only for the pnp ones. Reduce the value of the pull-up resistors to at least 1k or less (though i'm not exactly sure on this part) Also I recommend to put diodes across C-E of all transistor to dampen the oscillations/spikes that may occur.
Or better, buy a SG3525/KA3525 which has "totem pole" output stages :)
Thu May 31 2007, 08:48PM
The basic design looks ok but;
Is the duty very near 50%? Even if it is very close, unless it's EXACTLY 50% you will get 'flux walking'
each cycle will add a little dc current to the primary.
The cure is a capacitor in series with the primary.
the value of capacitance should be very large compared to the value that would resonate with the GDT inductance at the operating frequency.
You could instead add resistance (say 5 to 10 ohms) in series with the GDT primary which would serve the same purpose.
Thu May 31 2007, 09:04PM
The npn gets base drive from the 15k pull-up. The values are large, and should be about 180-220 ohms for the given transistors. Next time I go shopping I'm definitely getting SG3525s.
The driver is designed so the primary is shorted to ground during the off-time. (at least it is supposed to be.) Would the "flux still walk" with the primary shorted, or does it get reset? The design did work well from what I remember, tomorrow I'll do some breadboarding and try your suggestions. Hopefully it's just a faulty connection somewhere.
Fri Jun 01 2007, 08:22AM
You need to decrease the pull-up resistors on the TL494 outputs, and turn all your transistors round so they are operating as emitter followers instead of common emitter amplifiers.
Fri Jun 01 2007, 09:59AM
jmartis is correct, the pnp transistors will allways be ON (via either the TL494 or the npn base-emitter).
Steve's suggestion is the most common/simple way to go,
I still think a capacitor in series with the primary will be required.
I'd also put diodes from 0V to both sides of the transformer, and another two from the transformer connections to +V
to protect the transistors from inductance spikes from the primary.
Fri Jun 01 2007, 11:07AM
Yes! Steve's suggestion worked perfectly! The waveform looks better too. I'll put in some diodes and a DC blocking cap and it will be ready. I can't thank you guys enough! smile
Marko
Fri Jun 01 2007, 08:22PM
Just to add, with bipolar transistors you absolutely *must* use free wheeling diodes since they don't have any intristic diodes.
Without diodes on SG3525 I could get sme really serious ringing in deadtime, even up to lower treshold of 2V.
A bridge of 1N5819's clamped it to some 0.5V and mosfets were really happy.
