  • Guests: 33
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Signal generator output conversion to 2KV
1 2 3 4
Energyman
Sat May 19 2007, 04:03AM Print
Energyman Registered Member #788 Joined: Sat May 19 2007, 02:31AM
Hi,
I am a newbie with a fairly basic understanding of electronics. I want to convert a 12v output from my signal generator (square wave) to about 2KV without changing the frequency at all. I feel that this should be a fairly simple task but I have Googled till I am blue in the face with no results. I am working with frequencies in the range of 1.2 - 1.3 Mhz and I am using the output to generate scalar waves through about 10 ohms of coil.
Any advice would be gratefully received.
Thanks in advance,
Sat May 19 2007, 04:36AM
How much power are you using?
It should be pretty strait forward to feed the output of the signal generator into a gate driver such as a tc4422, and then feed that into a high voltage mosfet in an open collector scheme.
Energyman
Sat May 19 2007, 05:21AM
I am not using much power at all - 2 watts or so.
Your reply falls outside my knowledge base I am afraid. Any idea where I might find the resources for this (plans). I have had a look at the tc4422 and this seems simple enough but I have had no experience using hv mosfets.
Sat May 19 2007, 08:10AM
Good Luck !
At 1.25 MHz for 2kV the output would have to change at more than 5 gigavolts per second
which presents a few challenges, though it can be done.
Neither I nor this forum (as far as I know) accept the existence of electromagnetic scalar waves
but consider such things under the category pseudo-science, which is banned from 4HV.
What do you think scalar waves are, and how do you intend to produce them?
Energyman
Sat May 19 2007, 09:52AM
Hi,
I am using a caduceus coil to produce scalar waves. Scalar waves were being researched by Tesla. I hope that you are not saying that Tesla was a pseudo-scientist! Not on this forum, anyway!
There is plenty of info. on the net about scalar waves and I am not going to justify their existance here so I hope that keeps me on safe ground as far as the rules go.
I am glad that you think it can be done Suleiman. Any practical advice will be gratefully received.
Thanks,
Sat May 19 2007, 10:53AM
Scalar waves and caduceus coils are totally unacceptable topics for this forum, so let's have no more talk of them.
If I wanted to boost the output of a signal generator to 2kV (which is a perfectly acceptable topic of discussion) I would reach for a large vacuum tube of some sort. Probably a tetrode like the 6146 or 811A.
Energyman
Sun May 20 2007, 06:21AM
Hi Steve,
I don't want to talk about scalar waves only the electronics so we are clear on this.
Thanks for the input on the valves. Again, any idea where I can find the resources to put together a circuit. I am not adverse to paying for it if somebody has the knowledge and the time to put something together.
Sun May 20 2007, 06:35AM
I could build you a system to do what you want, but I can only make it a a spec defined in the real world (say, will drive a 2kv square wave @ 1.5MHz with rise and fall times of Xns into a 1meg load with 1pf of capacitance) since I do not expect your experiment to go anywhere. I charge $10/hr work + parts.
Energyman
Sun May 20 2007, 07:28AM
Thanks for the offer.
Sent you a pm
Bored Chemist
Sun May 20 2007, 08:25AM
Feeding that voltage into 1Mohm I can just about believe. Into (as stated in the initial post) about 10 ohms would need an inconveniently large power. Where do you plan to get 400Kw from?
Also, a 2KV sine wave at 1.MHz needs a slew rate of 5GV/sec, but a square wave takes a lot more. To get a decent square you will need up to the fifth harmonic and probably the 11th.
These numbers are just silly.
They might be achieved by someone with a military budget, but not by a home experimenter.
Why go ot all that effort and expenditure for something that's a myth anyway?
