  • Guests: 38
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
PCB design + PCB finishing/coating
Dago
Thu May 17 2007, 11:26PM Print
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I just finished designing the PCB for my next induction heater control circuit, and I was wondering about the use of a big groundplane in the toplayer. I know a big groundplane can be a very good thing or a very bad thing, depending on lots of factors. I'm pretty sure it wont matter that much in such a low frequency (20-100kHz) circuit like this but I want to learn how to do it properly. What are the things I should look out for when using a groundfill? When should I use groundfill? Should I use groundfill in my induction heater control board?
The toplayer (red) is for GND + VCC (there a few other traces on the toplayer but GND + VCC mainly) and the bottom layer is for everything else (some GND + VCC traces to components that cant be soldered on the toplayer like filter lytics).
No groundfill: Link2
Groundfill: Link2
Heres (most of) the circuit: Link2 then theres the SG3524 VCO + couple gate driver chips.
Please give advice in the groundfill matter or the PCB design in general (if you can spot something wrong with it).
Then to my other question, what would be a good finish/coating for a homemade PCB? I've heard some diffrent techniques:
Protective lacquer which functions as a flux too. Sounds expensive, but kinda handy.
Chemical tinning which involves soaking the board in some chemical for a few minutes and it gives a tincoat. Sound very nice and my chemist friend said it wouldnt be too expensive/hard to make the stuff (I cant find the commercial stuff from anywhere in here).
Then theres one option where you "paint" the board with tin paste and melt it in a hot oven or with a hot air blower. Sounds interesting and pretty inexpensive but not sure how well this works.
Fri May 18 2007, 12:04AM
As to the ground plane, I would throw it in. Some of the RF nuts might have some better advice, but for stuff like this they generally don't hurt.
As to the tinning, I have had good luck with a nice fat soldering iron and some solder. Just take a flux pen (or any type of flux for that matter, I like the pens) and flux up the board nice and good, take a nice beefy soldering iron (I use a 50w temp regulated weller for everything I do...) and melt solder down everywhere. A q-tip soaked in flux can help even it out for the really big areas. But really, you don't need to worry about it at all, the boards work just fine with bare copper exposed (although rework can be a pain if it gets too corroded)
ragnar
Fri May 18 2007, 12:37AM
It probably won't matter too much, but I think your traces are a little thin... especially if you're going to homemake the board -- you may have some issues with the pad ripping off when you try to drill a hole in it... which makes things particularly difficult if you want double-sided boards -- if you've done it before though, you'll know from experience.
Did you autoroute the board? My suggestion would be to fatten up what traces you can... especially traces going to GDTs etc. Sure, it's no big deal, but it's good habit, I suppose. ^.^
A groundplane will make the board a little more difficult to solder (without commercial soldermasking, that is), but is usually worth it in the long run. Your signals will be cleaner, and everything feels better when you see it on the scope.
I've used chemical tinning, and as a person that dislikes the wet PCB process, it is a bit of a pain. Proper flux (yes, that acidic yellow goo, where the fumes burn the inside of your mouth and taste horrible) works miracles on copper boards you want to tin. If you flux the whole board with a tissue and use a hot iron, you'll get beautiful results.
Part Scavenger
Fri May 18 2007, 01:57AM
For a protective coating, I've started using spray polyurethane. Just spray it on the entire board, I usually do a couple thin coats. It burns right off when applying the solder (right up to the edge of the solder), seems to work quite nicely. However, I only started doing this about 2-3months ago, but I sure don't expect any problems long term
Here's a pic of my latest DRSSTC control...
1179453448 79 FT25323 Pictureboard
1179453448 79 FT25323 Picture079
Oh, and I'll also make a plug for wider traces. A groundplane will decrease the resistance, make the signals look better, and if you're doing the toner method for etching the board, it will made the process easier (the toner tends to stick better with more than just the traces.) If you want more info, I etch boards ALL the time, and as cheaply as possible. Just drop me a line and I'll give you all the details.
thedatastream
Fri May 18 2007, 08:44AM
I would always fill with ground by default, but that is more habit than experience.
One thing I've learnt from doing high speed digital design (up to 500MHz) is that the return path (ground) is just as important as the "signal" path.
I would always thicken up my power supply traces as well
James
Dago
Fri May 18 2007, 09:27AM
BlackPlasma wrote ...
Yeah thickening the traces is a good idea, but I'm pretty sure it wont really matter for drilling since I've done smaller SMD boards with vias with no problems ( Link2 some holes not matching up properly because the films moved when exposing).
Edit: fattened all the power carrying lines: Link2
And no, no autoroute, I have never managed to make anything proper with it.
Aand groundplane shouldnt make the soldering that much more difficult because eagle leaves space around ALL pads in a groundfill so its easier to solder them.
But I'll prolly have to buy some tin paste and flux to try the diffrent coating methods.
thedatastream
Fri May 18 2007, 10:10AM
You could also put a ground plane on the bottom too.
Make sure you name the plane GND in Eagle (or whatever you've called your circuit reference)
Always select "thermals on" when pouring a plane - it makes soldering it much easier
Dr. Slack
Fri May 18 2007, 10:21AM
Ground plane is good, but use automatic "groundfill" with caution.
Too many times I have seen designs where as the last step the engineer has said "and fill all the remaining gaps with ground plane". The problem is that it's the *remaining* gaps. If you have traces going all over the place, the ground might end up not being well connected. The last thing you want is a long thin bit of ground snaking its way from the main ground to a large, otherwise isolated, patch. The term we use is "ground lace curtain" instead of ground plane, where the hoped-for low impedance plane has been shredded by signal tracks carving their way through it.
What you must consider is the current flows in the ground to be every bit as important as current flows in your signal tracks. It's good practice to route explicit ground tracks, with adequate width, in low inductance pairs with all of your signal tracks. This ensures that you have thought about current loop area, ground current injection from one part to another etc etc. Now when you do the last ground fill, it should only make thing things better. As an aside, if you didn't know you had to consider ground currents or are unable to estimate where they might flow, you are at risk of being bitten by unexpected circuit behaviour, especially unintentional coupling between things that shouldn't.
If you have just routed the signal tracks and then done a fill, it's good practice to explicitly go look for ground connectivity problems. Look for isolated lands, look for long thin bits of ground, check especially in the area of any long signal tracks which cut across the ground plane, whether you were expecting any ground return current to flow across that slot. Usually all of these problems can be corrected by a few extra connections to repair the tears in the ground lace curtain, or to move a signal track so that it doesn't tear.
Fri May 18 2007, 12:35PM
I totally agree. I do all this stuff in my commercial board designs whenever I'm restricted to 2 layers for budget reasons. But you have to wonder whether the average hobbyist really wants to know.
The most foolproof form of construction for RF circuits is the "Manhattan" or "Dead Bug" style, where you make your circuit with squares of copperclad glued to an unbroken solid groundplane. It's hard to screw up an RF circuit if you build it in that style. You can screw it up, but you actually have to try.
