  • Guests: 46
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Zener diode forward voltage problem
AndrewM
Tue May 08 2007, 05:17PM Print
I have a problem with some non-intuitive behavior from a zener diode.
When connected "forwardly" with 13k of resistance upstream and a 12V supply, I see 11V at the diode. I would expect 0.7V, the "standard" silicon diode forward voltage.
Why is this?!
Tue May 08 2007, 06:37PM
Well, that is weird... all my my zeners are around the typical 1V Vfwd range. Do you have a part number on that diode? And uhh, you are sure you have it the right way around, yes? angry
Tue May 08 2007, 10:16PM
is the diode actually 2 zener diodes back to back? That would explain the large voltage drop regardless of polarity...
AndrewM
Tue May 08 2007, 11:55PM
Ok, here are some more details:
Its a 1N4568A connected to a ~13V supply through 13k in series. In the "normal" direction I measure 6.4V (yay!). In the "backwards" (forward) direction, I measure 11V. I'm sure this diode is "good".
Curve trace shows knee in the forward direction at 10.8V.
Discuss!?
Wed May 09 2007, 08:08AM
A single junction zener/avalanche reference diode usually has minimum dV/dT when the reference voltage is in the 4 to 5 volt range,
I'm not sure, but I suspect that the 1N4568 is composed of more than one junction
a common 'trick' is to use a zener of about 5v6 in series with a forward-biased diode
the zener would have dV/dT of about +2mV/degree, cancelled by the diode's -2mV/degree
so maybe that's what's inside the device?
Wed May 09 2007, 05:46PM
Yes, some precision "zeners" are two diodes connected in series internally.
