  • Guests: 28
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
MIDI player walkman?
ShawnLG
Thu May 03 2007, 05:44PM Print
Is it possible to build one?
I have never seen one before and it would be possible with today's technology to build one using some static ram to store the MIDI files. Since MIDI files do not need a lot of CPU power to execute, a PIC or some other microcontroller can do the task of driving a sound synthesis IC. Any thoughts?
Electroholic
Thu May 03 2007, 06:37PM
they already made an open source mp3 player, i think its called daisy mp3 player.
Bjørn
Thu May 03 2007, 07:02PM
That would not be terribly difficult. You can get microcontrollers with at least 256kB of Flash memory that are powerful enough to do sound synthesis in software, then you can do it on a single chip. It is also simple to interface to cheap flash cards, then you can access a gigabyte worth of MIDI files if you can find that many.
Wolfram
Thu May 03 2007, 10:20PM
Check out the VS1033. This chip can play MP3, WMA, MIDI and some other stuff. It is also relatively cheap (around 10 bucks), quite easy to use, and availabe from sparkfun.
I'm still dreaming about a SID walkman. It would be possible to get the whole HVSC (33000 songs) on a single 512MB memory card.
Fri May 04 2007, 09:35AM
Wow, that VS1033 chip is pretty impressive. I can't believe they managed (or bothered!) to cram a General MIDI synth onto it. Maybe it's meant for some kind of smartphone, so you can have MIDI ringtones and listen to MP3s.
Also, Mikkel, I agree you need to build a SID walkman smile If you put a VS1033 in there, you could play every other file format under the sun too! Probably the hardest part of this project would be writing the FAT32 filesystem driver so that your uC could read a PC formatted memory card.
I found a neat device a while back that might help with this: the Vinculum from FTDI Link2 You plug a USB flash drive into it and it decodes the file system for you using DOS-like commands that you send over SPI. I bought an eval board for it but couldn't think of anything leet to do with it.
FastMHz
Fri May 04 2007, 06:04PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
I know it's more fun to build one from scratch...but the GP2X can play SIDs, MODs and MIDI is almost here.
ShawnLG
Sat May 12 2007, 07:26PM
I have found a YMF262M synth chip on a PC sound card. It also uses a DAC chip. Judgeing from it's register interface, it should not be to difficult to interface it with a microcontroller. Only an eight bit data bus.
"I know it's more fun to build one from scratch..."
I know it would be. Also don't need anything too complex or the project would never be completed.
