  • Guests: 31
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
carbon fiber ... wire?
Sat Apr 28 2007, 11:27PM Print
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
Hey all, not sure if this is general electronic or high voltage electronics, I'll take the path of generality.
I found some coiled up wire in an unmarked box. At first I thought it was some broken fiber optic cable, then I stripped it and the fibers are black... carbon, me thinks. So it tests at ~ 184 ohms per inch (35" = 6.44Kohm).
It has some kind of fiber/fluffy plastic (teflon foam?) insulation inside a heavy silicone jacket. it's 8mm dia.
Does anyone have a suggestion to what this might be? the only reason I suspected it might be an electrical conductor is because there are lightning bolts printed on the jacket, with a resistor symbol attached. is this some kind of fuse wire maybe? pics when I get camera charged up :)
if nothing else maybe I can use the carbon fiber and some resin to make some cool carbon fiber accents for various things....
-Doug
Sat Apr 28 2007, 11:31PM
That is the wire you use to connect your spark plugs to your distributor in you car. The resistance helps keep EMI down.
It is pretty much 100% useless for us... Ebay maybe
ShawnLG
Sun Apr 29 2007, 01:19AM
"It is pretty much 100% useless for us... "
I would not say that. Some length of it could be used on the output of a Cockcroft Walton generator to protect the diodes from peak current.
Sun Apr 29 2007, 04:35AM
People have tried that, but the ends where you have a carbon/metal contact have a tendency to erode away.
