  • Guests: 28
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Can't explain this phenomenon of ohm readings.
MikeT1982
Thu Apr 26 2007, 08:20PM Print
MikeT1982 Registered Member #621 Joined: Sun Apr 01 2007, 12:37AM
I took my Fluke meter and measured a 20Kohm Ohmite Wirewound resistor and not suprisingly I get 19.8 kOhms.
However, when I measure the primary side of my NST I get 5.1 Ohms. This confuses me as the Primary side draws 1.17 amps at 120 volts! All 3 France's read almost exactly 5.1 ohms and work fine. What I can't understand is why Ohm's law equation fails me here. If I plug in 1.17 amps and 120 volts into ohms law, the NST's Primary should be 102.56 ohms. Please help me to understand what the heck is the reason for this.
Thanks,
Mike
Ken M.
Thu Apr 26 2007, 08:24PM
I would say because its a transformer and when power is applied the flux lines shift the resistive values...thats the best explaination I can give...Never really bothered to ask why, just know that coils act funny with resistivity (Probly not a word).
MikeT1982
Thu Apr 26 2007, 08:38PM
Interesting, that makes sense man thanks. Maybe this explains why even these little 4kV@30mA Frances dim the room lights for a split second when plugged in. If 120 volts surged into the 5.1 ohms my Fluke meter gives then we'd have a current draw of like 24 amps...it must drop reeeal fast once the coil energizes if thats the case.
Reaching
Thu Apr 26 2007, 08:40PM
thats just the dc resistance you measured. but since you work with ac and an inductance, you cant use ohms law here to calculate the amperage.
Marko
Thu Apr 26 2007, 08:42PM
Nothing is 'acting funny with resistivity', your meter only and rightly gave you the reading of DC resistance of primary winding.
When plugged into line, the inductive resistance X will be what will limit your current mostly.
102.56 ohms is your primary impedance and not resistance Z wich you apply the ohm's law to.
Inductance causes the current to lage the voltage for 90 degrees.
So Z = sqrt(R^2 + X^2).
The ohmic resistance of your primary winding should actually be smallest possible because it just represents loss; an ideal transformer would have no ohmic winding resistance at all.
r3d
Thu Apr 26 2007, 08:43PM
r3d Registered Member #532 Joined: Sat Feb 17 2007, 05:00PM
Every transformer pulls a lot of current when pluged in, especially those with 300VA+! For them you have device called "soft start" that minimises the current they can draw!
And every single component has different resistance when measured without current passing thru it and with current passing thru it.
Thu Apr 26 2007, 09:55PM
NO
Just... NO!
Pleaaaase, i dont mind people trying to help, but if you dont know what you are talking about, you are just starting more misconceptions about the nature of electronics!
Simon
Thu Apr 26 2007, 11:49PM
wrote ...
It's strictly true but can be ignored in just about any practical situation, including this one.
ragnar
Fri Apr 27 2007, 12:17AM
Thanks Steve! R3D, WhiteArc, don't make stuff up. That's my job wink
MikeT, Firkragg's explanation is correct. Or, less accurately (assuming a zero resistance), you can calculate the "inductive reactance" using the following formula:
R = 2pi * f * L
where R is your 'reactance',
f is your mains frequency,
L is the inductance.
MikeT1982
Fri Apr 27 2007, 03:12AM
Thanks. This is what I like about this board is there's people willing to help out. I wanted to find a board less advanced since I often have "elemetary" questions but am doing a decently big project. But this place keeps me coming back because I know I will get educated answers, I appreciate all viewpoints too regardless of how precise. Orignally I had some thoughts that something funky was going on being that it was a transformer and a coil with AC current but couldn't figure quite what would do that. Now I can see that the ohms law equation V=IR can't be used alone on an AC driven coil like this to see how it reacts when live.
