  • Guests: 33
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Plexi glass and lighting.
Ken M.
Sun Apr 22 2007, 01:24AM Print
As many know CH_R is the best crafter of plexi glass on the forums,(there may be others but I haven't seen many) and after seeing his use of LED's embeded into the glass, as well as doing it to some exstent with my TC project I decided to try some of the other LED's I had sitting around and find out the subsequnt colors and effects the had when lighting plexi glass.
Here is Plexi glass with 1 UV LED implanted.
SD530272
Here is a Red LED.
SD530270
Heres (My favorite) a Blue LED.
SD530269
Lastly a Green LED.
SD530268
Each LED is a clear lens ~10,000MCD brightness.
Also I was just using a 1k resistor and a 9v cell.
ragnar
Sun Apr 22 2007, 02:22AM
The forward voltage drop of most blue/green/white LEDs is around 3.6V
(9.0V - 3.6V) / (0.02A) = 270
Try a 270-ohm resistor instead.
1177208551 63 FT24138 Elsingle3
1177208551 63 FT24138 Elsingle4
Ken M.
Sun Apr 22 2007, 03:06AM
I was more concerned about over powering it, plus 1k was the resistor I had on hand, besides all the LED's where used with gator clamps, for quick way to connect them to the power source and be able to interchange each 1 pretty quickly, especially considering all my LED's got mixed up and are in 1 pile, and since they all have clear lenss...I have no way of telling what color each LED will produce untill I power it.
