  • Guests: 29
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Electrostatic actuator
DrZoidberg
Sat Apr 14 2007, 12:37PM Print
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
Hi,
I know a piezo ceramic is an electrostatic actuator but I want something that moves several mm instead of just a few µm.
The force doesn't need to be that big. So I was thinking I could simply use two metal plates with an elastic material e.g. rubber in between. Or better yet several layers of metal sheets and rubber.
That would basically be a capacitor that contracts when a voltage is applied.
But it's difficult to get a useful amount of force out of that. I'd need to replace the rubber with something that has a higher dielectric constant, a higher breakdown voltage and is more elastic. Or at least one of the three.
Can anyone give me a hint here? thanks.
Electroholic
Sat Apr 14 2007, 01:37PM
just google "amplified piezo actuator"
