  • Guests: 47
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
simple induction heating
Sam
Tue Apr 10 2007, 09:03PM Print
Sam Registered Member #227 Joined: Mon Feb 20 2006, 10:47PM
I was looking around at this induction heatinglately, googleing some stuff and thinking a bit.
I was wondering if it would be ok to use 2 IGBTs in a half bridge arangment, driven my (just a though) my old IGGy driver and with a cap bank of some bottle caps from my MOTTC or an MMC I have...
I'm sure I can find some wire or copper tubing some where.
Would this maybe be a start?
BTW, the driver supplies about 15-20v DC @ 5A and is variable,
EDIT: and what about using my MOT's (on a lower voltage) as the coil PSU.?
Wolfram
Tue Apr 10 2007, 09:22PM
Do you want to use the IGBT half bridge to drive an ignition coil to make HV, then make an induction heater with a spark gap, or do you want to drive the work coil directly from the IGBT bridge? Judging from the talk about the bottle caps, I guess the former. In that case; why not just connect the work coil directly to the output of the IGBT bridge? Should be a lot simpler and more efficient.
Sam
Tue Apr 10 2007, 09:32PM
I was thinking of notspark gap, just rinning the IGBT with the coil driver, then some relitivly HV in to the IGBT then out to the heating coil.
EDIT: I dug out my IGBTs and drove them with the Iggy driver, it works good. Nowto make a 1/2 bridge and a HVPSU
What should my voltage/current be for the heating coil curcuit?
maybe 300-400v @ 500-750 mA?
Experimentonomen
Tue Aug 14 2007, 05:58PM
Maybe alittle late but heres a circuit that i used for induction heating, got a M12 nut nice and yellow, tho it eats the fets after a while: Link2
