  • Guests: 25
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
net width as function of current.
SkullCurrentResistor
Tue Apr 10 2007, 04:43PM Print
SkullCurrentResistor Registered Member #308 Joined: Sun Mar 12 2006, 03:30PM
I have been looking around the Internet but apprently im not capable of finding information regarding the witdth og the nets on a printboard when taking into account the current that has to go through them. The fFact is that i am designing a board but im not sure if the nets are capable of handling the current i am operating with. How do people determine such things?
/SCR
ConKbot of Doom
Tue Apr 10 2007, 05:45PM
I googled for 'PCB width current'
found this
Just a terminology difference it sounds like.
Tue Apr 10 2007, 07:15PM
Basically just two equations you need to know:
I = 0.015*temprise*CrosssectionalArea^0.735 (traces internal to the PCB board)
I = 0.065*temprise*CrosssectionalArea^0.673 (external traces)
where temprise in C and Crosssectional area in sq-mils.
1oz copper is approximately 1.4mils thick, 2.8mils thick for 2oz copper, etc...
thedatastream
Tue Apr 10 2007, 09:11PM
The resistivity of copper is about 17 nano-ohms/metre Link2
Resistivty is R = ( rho * L ) / XSA
where:
rho is the resistivity (as above)
L is the length of the trace in metres
XSA is the cross sectional area of the conductors in metres squared
1oz copper is the standard weight for PCB traces unless specified otherwise - this is 0.035mm thick.
Knowing the above allows you to calculate the resistance of the trace. You can then calculate the voltage drop using V = I*R and the power dissipation using P = I*I*R (or the equivalent)
Calculating the temp rise of a stretch of track depends on many factors including orientation of the board (horizontal or vertical) and the rate of airflow (if any). However for a first approximation, the equations EVR provided are probably OK.
Your PCB trace should not reach above a certain temperature in it's worst case operating environment, and this temperature is dependant on the material. FR4 is the standard material for double sided PCBs and its continuous operating temperature is about 130°C Link2
p.s. 1 mil is 1/1000 of an inch
HTH
James
