  • Guests: 37
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Underground acoustic wave propagation
TheMerovingian
Mon Apr 02 2007, 08:23AM Print
I was thinking about the small underground explosion experiments I have carried to take some nice photos. What would happen if I plant a microphone, say 1 mt from the explosion source? Would I be able to detect reflections from, say, house basement, water pipes, bedrock? It would be a cool experiment. Is there a theory , or a model , I can use to detect these things? Of course my setup is fairly unrepeteable, since the explosions cannot be reproduced exactly.
Dr. Shark
Mon Apr 02 2007, 09:52AM
Would you care to explain your setup for photographing underground explosions? I take it you blow up some dirt and take a picture of it falling down? smile
Anyway, rearding your question; sure you could pick up "something", the difficulty would be in interpreting what you are picking up. In order to infer some kind of spacial structure (not just a dumb distance measurement) you would need an array of microphones. Most of the work would then be in the data analysis, but I am fairly sure that with the required programming skills even a fairly simple setup could get you "useful" data.
TheMerovingian
Mon Apr 02 2007, 10:16AM
The photograph was taken on the surface, but the microphone needs to be buried.
I would be curious to see the wave pattern of such an experiment. I'll try it.
