  • Guests: 39
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Some quick questions about some old parts
Myke
Mon Apr 02 2007, 12:47AM Print
I'm wondering what could this be?
1175474473 540 FT0 Img 1948
1175474473 540 FT0 Img 1961
1175474473 540 FT0 Img 1960
And I wanted to know how I could zero this meter?
1175474774 540 FT0 Img 1969
It has a glass shield soldered on to it.
Is there any use for a current xfmr that has a freq range of 350-1000 Hz?
Wolfram
Mon Apr 02 2007, 01:51AM
The first thing looks a bit like a buzzer to me. What happens when you apply a voltage to it?
Mon Apr 02 2007, 02:21AM
I would say buzzer for the first one, possibly an overtemp switch.
As to the meter, there isn't any chance that you can pull some screws off the back and pull the whole assembly out? Short of that, you could rotate it at an odd angle ;)
As to the current transformer, it would probably work at 60hz (although not very well methinks)...
Mon Apr 02 2007, 07:43PM
The meter is 1mA full-scale-deflection, scaled 0 to 1.
To convert to a voltmeter add a (1kOhm x Voltage) resistor in series with the meter.
e.g. to use it for 0-1 kV use a 1 MOhm resistor.
NOTE: 1mA x 1kV = 1 Watt, so use a 2W or more rated resistor.
I've no idea what the first item is.
