  • Guests: 52
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
My new CNC toy :)
Tim Koene
Fri Feb 24 2006, 10:21PM Print
Tim Koene Registered Member #37 Joined: Sun Feb 05 2006, 05:35PM
I have succesfully interfaced with a pick and place robot I have acquired. It will do my bidding. Work envelope is 60*70cm, resolution is 0.01mm and mechanical and electrical repeatability is 0.05mm. It is fast: about 2m/s traverse speeds. Did I mention it is fast? It is also built with industrial grade mechanics and will be very suitable for very good CNC routing. It came with two 5phase 350W stepper motors, direct belt drive and 2400N nominal load linear bearings.
Check out the video ( 9,8Mb ) Here
I am going to have so much fun :D
Hazmatt_(The Underdog)
Fri Feb 24 2006, 11:16PM
NIICCCEEE!!
how about a CO2 laser! ;D That would make your power bill a bit rediculous, but I think it would be pretty cool with a laser.
Carbon_Rod
Fri Feb 24 2006, 11:30PM
Wooot, You will have too much fun... =)
So next I wager a guess it’s a cutting coolant pump, vacuum tailing removal, and a sound suppression cabinet.
What CAM driver software do you use?
What’s the total travel distances (x,y,z)?
ragnar
Fri Feb 24 2006, 11:44PM
Rapid traverse CNC stuff is great, isn't it? =)
600mm x 700mm is amazing... what's the Z-travel, or is it only a two-and-a-half-axis machine? (e.g. Z axis is either "down" or "up")
I've had the privelege of working with a 25W CO2 laser laser cutter, 600mm x 550mm working area. Its max travel rate is probably ~10m/s... ridiculous. Annoys me a bit, because all the stuff is BELT-DRIVEN, and these aren't non-extensible kevlar-fibre belts or anything - they're semi-rubbery poly-god-knows-what-ylene.
When you're cutting very thin material at 25W, you've got to go fast to compensate for the thickness! I worry about its repeatability; belt stretch issues, overshooting, undershooting etc. The accel/decel curve is excessively steep, and the whole bench shakes when it starts stops... feels like the lens/carriage are staying still and it's moving the whole world (including the rest of the machine), somestimes.
Your robot looks very nice - none of this fabricated sheet metal rubbish, all machined aluminium! Heavy! I love it! =)
enjoy
Tipp
Sat Feb 25 2006, 01:36AM
Tipp Registered Member #215 Joined: Sun Feb 19 2006, 09:14PM
Very nice! Thats a real piece of art you have there. Can't wait to see it work it's magic on some material cheesey
kalenedrael
Sat Feb 25 2006, 03:42AM
kalenedrael Registered Member #5 Joined: Thu Feb 02 2006, 04:18AM
It's interesting to note that the resolution you stated on that robot is about one wavelength of CO2 laser light. You're almost at the point where accuracy will be limited by the optics of the laser rather than the mechanical parts.
Tim Koene
Sat Feb 25 2006, 05:49PM
Well at the moment it is X and Y travel only, and I have yet to reach the limits of how fast the thing will move. But the weight moving around at such speeds makes my table wobbly so I do not dare to go the full monty yet. It still needs a good Z-axis and a proper Linux/EMC controller, but hey, I am not complaining!
What I am planning to do is PCB routing and building speakers.
I will keep you posted.
Pcnerd
Sat Feb 25 2006, 06:50PM
Pcnerd Registered Member #88 Joined: Thu Feb 09 2006, 02:37PM
building speakers?
mwah.
I've got parts enough for a cnc driver now too ( drawwing/foamcutting).
I only miss the driver and need to build it
but I hope to get the driver ic's (l297 & l298) soon.
After that I hope to make a cnc for making pcb's with a multitool oid.
Maz
Sat Feb 25 2006, 11:09PM
Maz Registered Member #111 Joined: Fri Feb 10 2006, 01:04AM
you ever consider making it a small buisness?
the computer modding community has been raving for acrylic windows for a while now. and if you could rout a design into them.......they would eat it up.
Tim Koene
Sun Feb 26 2006, 12:22PM
Yes I have considered making it a business. I am still considering it. Custom PC modding is high on my list as well. But I still need to do a lot of work on it so I do not want to get ahead of myself.
