  • Guests: 22
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Need help with PWM IC
Sat Mar 24 2007, 03:12PM Print
Hello all, I need some help with PWM IC SG3525AN, datasheet is -here-. Since I can't make out much from the datasheet, it would be great if someone more "experinced" would help me with these questions:
1) How do I set Duty Cycle on this IC?
2) What are the Discharge and Compensation pins for?
3) How big capacitor to connect to the Soft Start pin?
4) Where do I connect all of the unused pins to, or leave them floating?
Thanks!
thedatastream
Sat Mar 24 2007, 09:26PM
This IC operates on the same principle as nearly all normal power supply PWM control ICs - a voltage reference is compared to a sawtooth ramp waveform. The ramp is generated by the oscillator and the reference voltage is generated by the error amplifier.
1) Look on page 4 of the datasheet at the diagram titled "Lab Test Fixture" and trace through the block diagram from the pot that says "PWM ADJ" and you can figure it out easily enough.
2) This discharges the oscillator resistor. A series resistor between it an the timing capacitor adds deadtime into the outputs.
Compensation sets the frequency response of the error amplifier and therefore the gain bandwisth of the circuit
3) Depends how long you want the soft start period to be. Datasheet gives the soft start current and threshold voltage so you can work out how long it would take before soft start finishes.
4) Depends on how your circuit is configured.
Recommended course of action: get the chip, build a simplfied lab test fixture and have a play aorund, measuring different points - you'll lear about it.
Also, get on the Texas Instruments website and download whatever application notes you can about SMPS design, they will give you the basic idea
HTH
James
Sun Mar 25 2007, 08:31AM
Ok thanks, I have one more question - what is the difference between duty cycle and dead-time? (decreasing duty cycle and increasing dead-time has the same effect, right?)
Marko
Sun Mar 25 2007, 08:07PM
Dead time is determined by resistor between pins 5 and 7 and fixed; it determines amximum allowed duty cycle and prevents possible shoot-trough and DC-bias saturation in some cases.
When pins are shorted together you'l be able to get very closely 50% duty cycle.
Bill G
Sun Mar 25 2007, 09:11PM
Bill G Registered Member #508 Joined: Sat Feb 10 2007, 01:57AM
Duty cycle is the ratio between on-time and off-time of the squarewave.
Dead Time is a specific period of time inserted bt the PWM IC to ensure that one MOSFET or IGBT has time to turn off before the other turns on.
Hope this helps ...
