  • Guests: 61
Where to get high current diodes?
Colin 99
Sat Mar 17 2007, 01:30AM Print
Colin 99 Registered Member #192 Joined: Fri Feb 17 2006, 03:08AM
Hello,
I was trying to find a manufacturer that I could sample some diodes from. I need 20 amp ones in a TO-220 or TO-247 type of case.
Also where can I get mini brick diodes, SOT-227s also called ISOTOPs. I tried Fairchild and the ones that they have are 33 amps, I need a higher current rating at 600 volts.
thanks,
edit: I just found them at st.com, they carry both kinds. thanks anyway ! If anyone knows of other manufacturers please let me know.
Shaun
Sat Mar 17 2007, 04:55AM
Last time I checked (summer) failrchild still samples... But I doubt you will find any minibricks up for sample.
Also, what rating of a diode do you need? 30a/600v is 18kw... BTW, The peak current is orders of magnitude higher that the average (diodes and scr's have enormously high peak ratings compared to igbts or wore yet fets).
ragnar
Sun Mar 18 2007, 10:14PM
I have lots of MUR3020 -- 200V 30A diodes, which I can sell you quite cheaply, see here:
Mon Mar 19 2007, 05:46PM
30a/600v is 18kw...
Sorry, that just struck a nerve. Its comments like that, which spread misconceptions. Its like giving a MOSFET some obsene KW rating by multiplying its stand off voltage and max current mad when in fact, such a number is COMPLETELY MEANINGLESS.
Mon Mar 19 2007, 06:36PM
Actually MUR3020 CAN provide 200V @ 30A dc average = 6 kW
Why does the description upset you Steve?
O.K. I admit that's running on the edge, but technically feasible
and in a TYPICAL circuit a less than (for safety margin) +/- 100Vpeak waveform is common so Vdc <= 100V
but other circuit configurations can be possible.
Marko
Mon Mar 19 2007, 07:22PM
You must always also consider safety margin for current, and consider maximum power dissipation you can allow to diode with your heatsinking capabilities. If it is a HF rectifier you also need to account recovry losses and etc, etc. So those numbers probably are more or less meaningless.
Mon Mar 19 2007, 08:08PM
Have you actually read the MUR3020 datasheet?
(e.g. Ifsm = 200A, If(av) = 15A per leg up to 150 C case temp. etc.)
Mon Mar 19 2007, 08:51PM
The thing is, you speak as if you are rectifying an already DC power source. In most power applications, the diode current is usually transient and periodic, where the actual power "processed" is considerably smaller than multiplying Vbreakdown by Iconduction. This doesnt even get into power factor either, so saying VA might be slightly less annoying, but its still silly to give semiconductors a "power" rating in my opinion (unless you are speaking of power dissipation).
Mon Mar 19 2007, 09:40PM
TRUE!
That's why I noted a 200V rectifier in TYPICAL circuits will only provide <= 100Vdc at rated current
So for example a squarewave OR sinewave ac source could only supply 3kW maximum continuous power via MUR3020 to stay within ratings, but for pulsed uni-polar sources 6kW IS achievable. (e.g. forward convertor)
I'm not saying that a reasonably well profesionally designed system would use semiconductors so close to the limit,
myself I usually use very conservative safety margins even for hobby use
as a little more cost in semiconductors saves a lot of frustrations,
but in these forums we often use semiconductors well beyond spec.sheet current ratings. cheesey
Anyway, this is off topic so I'll cease this line of discussion now, unless there are any serious rebuttals.
Colin 99
Tue Mar 20 2007, 12:30AM
Well thanks for the offer but, 200 volts isn't going to do it. I need higher voltage too.
Must have more power !! amazed
I do have a bunch of MUR1660's, I guess I could parallel some.
Shaun
